I've been playing with the chart ui lately. I've modified the tooltip using a change node for a better view,
But after deployed, I noticed that the time has been converted from the LocaleTimeString format to timestamps.
How do I have this displayed in the LocaleTimeString format.
Without the modification, the time display is user friendly..
but the data are not quit visible....
When you need help it is a good idea to provide enough information for people to help you. You should provide
- the version of Node-Red and node.js you are running (you can get this from the NR startup log)
- the version of the dashboard you are running (also in the startup log)
- the device you are running NR on (Pi, Windows, Mac etc)
- are you using Home Assistant or Docker
- a small flow demonstrating the issue (capture the data you are sending to the chart by sending it to a
debugnode, then put that in aninjectnode and send it to your chart to make sure it replicates your issue. Then you can export that flow and attach it to a reply.)
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
