Email formatting
Hi, I want to format the msg.body property for an email.
I have two variable (lat & lon) for storing the location data. then I am formatting a link to match the google-maps links. This way the receiver should be able to open te link in google maps.
my msg.body looks like this:
msg.body = "Google Maps" + lat + "," + lon;
I am sending through a powershell script, because I want to change the user/password in the dashboard. I am using the below code to run the script.
The body of the email should be the link, but i get:
so somehow the "/" is converted to /. What am I doing wrong? :sweat_smile:
$EmailTo = "{{toemail}}"
$EmailFrom = "{{fromemail}}"
$Subject = "{{subject}}"
$Body = "{{body}}"
$SMTPServer = "{{smtpserver}}"
$SMTPPort = "{{smtmpport}}"
$SMTPMessage = New-Object System.Net.Mail.MailMessage($EmailFrom,$EmailTo,$Subject,$Body)
$SMTPClient = New-Object Net.Mail.SmtpClient($SmtpServer, $SMTPPort)
$SMTPClient.EnableSsl = $true
$SMTPClient.Credentials = New-Object System.Net.NetworkCredential("{{loginuser}}", "{{loginpass}}");
$SMTPClient.Send($SMTPMessage)
I simplified the email like this:
        "id": "84540a1d29575b19",
        "type": "template",
        "z": "3d58124abc08a456",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "$EmailTo = \"{{toemail}}\"\n$EmailFrom = \"{{fromemail}}\"\n$Subject = \"{{subject}}\" \n$Body = \"{{body}}\" \n$SMTPServer = \"{{smtpserver}}\" \n$SMTPPort = \"{{smtmpport}}\"\n$SMTPMessage = New-Object System.Net.Mail.MailMessage($EmailFrom,$EmailTo,$Subject,$Body)\n$SMTPClient = New-Object Net.Mail.SmtpClient($SmtpServer, $SMTPPort) \n$SMTPClient.EnableSsl = $true \n$SMTPClient.Credentials = New-Object System.Net.NetworkCredential(\"{{loginuser}}\", \"{{loginpass}}\"); \n$SMTPClient.Send($SMTPMessage)",
        "output": "str",
        "x": 940,
        "y": 1320,
                "21f793304c283f0a",
                "a8527b09e15f4de1"
        "id": "21f793304c283f0a",
        "type": "powershell",
        "x": 1190,
        "y": 1260,
        "id": "a8527b09e15f4de1",
        "type": "debug",
        "name": "simple mail output",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1190,
        "y": 1320,
        "id": "e62801d6acc7e33f",
        "type": "function",
        "name": "Format email",
        "func": "\nvar lat = \"LAT\";\nvar lon = \"LON\"\n\n\nmsg.body = \"https://maps.google.com/?q=\" + lat + \",\" + lon;\n\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 730,
        "y": 1320,
                "84540a1d29575b19",
                "6d5711d16d95e02b"
        "id": "6d5711d16d95e02b",
        "type": "debug",
        "name": "check flow variables",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1200,
        "y": 1220,
        "id": "71744ca1a1c4e1e0",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 530,
        "y": 1320,
                "e62801d6acc7e33f"
Her you can find some more details about the flow I am using:
https://flows.nodered.org/flow/6eef931189ce2697f7747dc976774367
Use {{{ }}}, triple Parenthesis in the template.
From the help text
Note: By default, mustache will escape any non-alphanumeric or HTML entities in the values it substitutes. To prevent this, use {{{triple}}} braces.
