Enable require() in Node.js Functions on FlowFuse Instance(s)
We're attempting to build a workflow where we need to validate the incoming webhook POST with a hashed value that's calculated from a shared key.
We're currently leveraging the node-red-contrib-crypto-js module but it requires the Shared Key/Secret Key field to be static/set in the ui field.
This is a multi-tenant workflow we need.
Is it possible to enable the ability to leverage require() in Function modules?
My engineer has asked so that we can attempt a solution "using crypto/crypto-js directly in a Function".
If this is not the best solution/not possible, we'd appreciate any other guidance. Would it be to just use multiple node-red-contrib-crypto-js modules on our workflow canvas and route to each one based on the tenant each event is assigned to for HMAC verification, then route back into our unified workflow?
Hi @JeremyCee welcome to the forum.
No, but you don't realy need to
You can simply add crypto-js to the setup tab.
Setup
Demo
Function code
const secretKey = 'mySecretKey'
msg.payload = CryptoJS.AES.encrypt(msg.payload, secretKey).toString()
return msg
Ahhh, that's the button we needed! Showing our newness to the community in more ways than one. Thank you for the clear steps/visuals.
