Hi Guys,
Overview: authentication project whereby the MQTT node receives a SHA256 hash as payload and then needs to hold the Hash temporary, while it runs an SQLite query on the user's table and digests (Sha256) each user details ( query response) + OTP and matches the 2 Hash values, and if they match, then pass a simple 1 or 0 or true or false
I was wondering if someone of you geniuses can assist/instruct me how to achieve this me with a flow, PLEASE.
Here is what I have :
Hardware - Raspberry Pi 4 ,
Node Red v 1.0.6
SQLite DB and tables sorted.
I have created a flow with dummy data for test convenience:
[{"id":"b4c6e58f.f560c8","type":"tab","label":"Read DB and Mtach ","disabled":false,"info":""},{"id":"8bff06e3.6a7a38","type":"sqlite","z":"b4c6e58f.f560c8","mydb":"9db34194.66aca","sqlquery":"fixed","sql":"SELECT * FROM USERS;\nreturn msg;","name":"psa.db USERS table read ","x":590,"y":540,"wires":[[]]},{"id":"58f29a5b.55dce4","type":"function","z":"b4c6e58f.f560c8","name":"????","func":"// Incoming payload : \n\n// Need only 2 values from payload as:\n\n// 1: \"accreq\":\"0e2934be714a95fb23bba4703435fc9bd7d81343d6006fcf29660efa08033677\"\n// 2: \"OTP\":1234\n\n\n\nreturn[{\"psa001/d1/user_input \":{\"user_emp_id\":102030,\"Name \":\"Peter\",\"Surname\":\"Dever\",\"PIN\":5054,\"OTP\":1234,\"Door ID\":1},\"accreq\":\"0e2934be714a95fb23bba4703435fc9bd7d81343d6006fcf29660efa08033677\"}];","outputs":1,"noerr":0,"x":830,"y":380,"wires":[["43707721.b79398","29ec6f88.a51c5"]]},{"id":"43707721.b79398","type":"function","z":"b4c6e58f.f560c8","name":"?????","func":"// needs to split each object from response qeuiry ,then \n// Use each object values + OTP value ( From top funtion node \" MQTT Payload Dummy Data\"), then \n// pass vaules to \"Encrypt node\" \n// Wait for respone from match node , then\n// if true / 1 / ok , then stop ,\n// if fals / 0 / no , then use next object vales in line + OTP value ( From top funtion node \" MQTT Payload Dummy Data\") \n\nreturn msg;","outputs":1,"noerr":0,"x":910,"y":440,"wires":[["213389a0.8cba36"]]},{"id":"a4d8217f.10ab8","type":"function","z":"b4c6e58f.f560c8","name":"MQTT Payload Dummy data ","func":"\nreturn[{\"psa001/d1/user_input \":{\"user_emp_id\":102030,\"Name \":\"Peter\",\"Surname\":\"Dever\",\"PIN\":5054,\"OTP\":1234,\"Door ID\":1},\"accreq\":\"0e2934be714a95fb23bba4703435fc9bd7d81343d6006fcf29660efa08033677\"}];","outputs":1,"noerr":0,"x":580,"y":380,"wires":[["58f29a5b.55dce4","88f939cc.46f298"]]},{"id":"a2294a8b.60b508","type":"inject","z":"b4c6e58f.f560c8","name":"Trigger Read req","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":320,"y":380,"wires":[["a4d8217f.10ab8"]]},{"id":"333c066c.67a18a","type":"inject","z":"b4c6e58f.f560c8","name":"Trigger read req ","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":320,"y":440,"wires":[["6e9c7373.a566bc"]]},{"id":"6e9c7373.a566bc","type":"function","z":"b4c6e58f.f560c8","name":"USERS READ Dummy data ","func":"//array[2]\n//0: object\n//user_name: \"Pieter\"\n//user_surname: \"Hattingh\"\n//User_pin: 5054\n//user_acc_level: 5\n//user_acc_code: 1\n//1: object\n//user_name: \"Jac\"\n//user_surname: \"McDonald\"\n//User_pin: 9874\n//user_acc_level: 5\n//user_acc_code: 1\n\nreturn[{\"user_name\":\"Pieter\",\"user_surname\":\"Hattingh\",\"User_pin\":5054,\"user_acc_level\":5,\"user_acc_code\":1},{\"user_name\":\"Jac\",\"user_surname\":\"McDonald\",\"User_pin\":9874,\"user_acc_level\":5,\"user_acc_code\":1}];","outputs":1,"noerr":0,"x":580,"y":440,"wires":[["43707721.b79398","ec66a8ee.53d7a8"]]},{"id":"ec66a8ee.53d7a8","type":"debug","z":"b4c6e58f.f560c8","name":"db read response - Users table ","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":910,"y":540,"wires":[]},{"id":"88f939cc.46f298","type":"debug","z":"b4c6e58f.f560c8","name":"MQTT1 data debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":870,"y":300,"wires":[]},{"id":"29ec6f88.a51c5","type":"match","z":"b4c6e58f.f560c8","name":"","rules":[{"property":"payload","propertyType":"msg","type":"eq","value":""}],"x":1230,"y":380,"wires":[["77a04e64.abbc4"],["34145822.788f48"]]},{"id":"213389a0.8cba36","type":"digest","z":"b4c6e58f.f560c8","name":"Encrypt ","algorithm":"SHA256","x":1080,"y":440,"wires":[["29ec6f88.a51c5"]]},{"id":"34145822.788f48","type":"function","z":"b4c6e58f.f560c8","name":"???? No Match , Try again ","func":"// If NOT match the send - fals / 0 \n// And try next usesr ( Obect details ) from quiery \nreturn msg;","outputs":1,"noerr":0,"x":1480,"y":420,"wires":[[]]},{"id":"77a04e64.abbc4","type":"function","z":"b4c6e58f.f560c8","name":"??? Match = true / 1 ","func":"// If msg.payload match = true or 1 or ok \n//Then return true with the user data AND\n// If user_acc_code = 1 \n// Then retrurn User name + \"Access Granted\"\n// Else return User name + \"Access Restricted\" \nreturn msg;","outputs":1,"noerr":0,"x":1460,"y":340,"wires":[[]]},{"id":"9db34194.66aca","type":"sqlitedb","z":"","db":"psa.db","mode":"RWC"}]
Your help will be greatly appreciated.
Thank you in advance
