Hi
I am using existing nodes (such as which node-red-contrib-mssql-plus) which is using the “standard” ‘configuration node’.
Mostly the configuration points to an external SQL db or ERP/SAP system for which the configuration is setup beforehand (at design time).
The problem is that selecting the configuration also need to happen at design time, where my requirement is for runtime.
My use case is set in a corporate multi plant environment(let say 7 plants), where node-red is used as a integration tool between business systems.
I have 1 common flow that needs to connect to 1 of the 7 plants on-premise manufacturing systems.
The 7 manufacturing systems has the same SQL structure and functionality, the only difference is their data at their respected plant.
Using the SQL connector as an example, I will have a http request that comes in, to update a value on the SQL db of 1 of the 7 plants.
The indication of which plant will come with the http in payload {“plant”:” “Plant 1”}
To satisfy the above use case, I need the pre-configuration (that has already been setup for each plant), to be selected at runtime by for example msg.payload.plant
This can normally be achieved by ‘Typed Inputs’
The problem that I have is that config-nodes does not have the functionality of ‘typed inputs’ for configuration elements.
For an existing node I have managed to ‘enhance’ the node to some degree, but my effort still falls short.
This is what I have done.
I have added a Typed Input for a ‘Dynamic Connection’
(My intent was to merge the new Dynamic Connection and the original config-node but I failed to do this.)
When the node gets initialised (or at least this is what I think is happening here), I left the ‘getting of the config node’, but change it from a const to a var.
function mssql(config) {
RED.nodes.createNode(this, config);
var mssqlCN = RED.nodes.getNode(config.mssqlCN); //this is the original configuration, might need to change to var
const node = this;
When the node gets called at runtime (node.on), I get the incoming typed input value (i.e. Plant1), and lookup its id from all loaded nodes (i.e. ‘28f23f6e8d6052e4’).
For this config-nosd it will have type = ‘MSSQL-CN’ and have a name of ‘Plant1’.
(I found that note all nodes might have names, others have ‘’nickname,; all have id’s though.)
I then get the new (dynamic) configuration node
node.on('input', function (msg) {
//this is the new connection that should be used that comes from msg
var mssqlCNdynamicLabel;
var mssqlCNdynamicValue;
mssqlCNdynamicLabel = RED.util.evaluateNodeProperty(config.mssqlCNdynamic, config.mssqlCNdynamicType, node, msg); //this should be enhanced for flow and global
RED.nodes.eachNode(function(node) {
if (node.type === "MSSQL-CN" && node.name === mssqlCNdynamicLabel ) {
mssqlCNdynamicValue = node.id;
mssqlCN = RED.nodes.getNode(mssqlCNdynamicValue); //this now sets the new connection
This works but I will like:
• The dynamic connection and original config-node to be merged
• Being able to have types inputs as well as a ‘standard’ config node
