nx2i
11 December 2023 14:59
1
I am having difficulties upgrading my node-red installation. The following command (and others) all return a 503 Error when run:
Running Node-RED install for user pi at /home/pi on raspbian
bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered ) --node18
with this result:
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED
Remove old version of Node-RED
Remove old version of Node.js v10.24.0
curl: (22) The requested URL returned error: 503
updates using apt also fail. The system is a Pi 4B running Buster
Colin
11 December 2023 15:13
2
nx2i:
With the same error? That suggests there is a problem with the pi apt repository. Show us what the command
sudo apt update
gives.
nx2i
11 December 2023 15:53
3
here's the apt command:
sudo apt update
Hit:1 https://repos.influxdata.com/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://apt.grafana.com stable InRelease
Hit:4 http://archive.raspberrypi.org/debian buster InRelease
Err:5 https://deb.nodesource.com/node_18.x nodistro InRelease
503 Service Unavailable [IP: 143.204.15.127 443]
Reading package lists... Done
Building dependency tree
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease 503 Service Unavailable [IP: 143.204.15.127 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Colin
11 December 2023 15:58
4
Can you open that in a browser? It is ok for me at the moment, so there is not a problem with the server.
Can you ping the server?
ping deb.nodesource.com
Edit: Obviously you can ping it, otherwise you would not get the 503 error.
nx2i
11 December 2023 16:43
5
using chromium on pi 4 in question returns:
503 Service Temporarily Unavailable
on another linux box running mint 21 (and firefox):
works OK.
ping deb.nodesource.com works OK on both machines
Colin
11 December 2023 16:46
6
Are they on the same local network?
Are you on a company network? If so then I suspect it is something on the network.
nx2i
11 December 2023 16:50
7
they at both on my home LAN.
Colin
11 December 2023 17:06
8
Connected to the same router the same way? Wired/wifi?
nx2i
11 December 2023 17:11
9
both ethernet wired to the same router
nx2i
11 December 2023 17:16
10
here's what nslookup shows for both machines:
from the linux mint 21 box:
nslookup deb.nodesource.com
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
deb.nodesource.com canonical name = deb.nodesource.com.cdn.cloudflare.net .
Address: 104.22.5.26
Address: 104.22.4.26
Address: 172.67.10.205
Address: 2606:4700:10::6816:41a
Address: 2606:4700:10::ac43:acd
Address: 2606:4700:10::6816:51a
from the pi4:
pi@pihome:~ $ nslookup deb.nodesource.com
Server: 208.67.222.222
Address: 208.67.222.222#53
Colin
11 December 2023 17:24
12
You have something very odd going on, as that is a different ip.
What about dig deb.nodesource.com
Colin
11 December 2023 17:28
13
And try rebooting the pi and the router.
nx2i
11 December 2023 17:45
14
I agree it quite odd....
I rebooted both router and Pi4. here's the output from dig on the pi4:
; <<>> DiG 9.11.5-P4-5.1+deb10u9-Raspbian <<>> deb.nodesource.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 3117
;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;deb.nodesource.com . IN A
;; ANSWER SECTION:
deb.nodesource.com . 216 IN CNAME deb.nodesource.com.cdn.cloudflare.net .
deb.nodesource.com.cdn.cloudflare.net . 216 IN A 104.22.4.26
deb.nodesource.com.cdn.cloudflare.net . 216 IN A 104.22.5.26
deb.nodesource.com.cdn.cloudflare.net . 216 IN A 172.67.10.205
;; Query time: 20 msec
;; SERVER: 208.67.222.222#53(208.67.222.222)
;; WHEN: Mon Dec 11 12:39:13 EST 2023
;; MSG SIZE rcvd: 146
after the reboot, the install script still fails with the 503 error
Colin
11 December 2023 18:00
15
See what this says
curl https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease|more
Edit:
Actually this might be more useful
wget https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease
nx2i
11 December 2023 21:40
16
--2023-12-11 16:39:51-- https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease
Resolving deb.nodesource.com (deb.nodesource.com )... 143.204.15.127
Connecting to deb.nodesource.com (deb.nodesource.com )|143.204.15.127|:443... connected.
HTTP request sent, awaiting response... 503 Service Unavailable
2023-12-11 16:39:52 ERROR 503: Service Unavailable.
looks like it goes to the wring URL...
Colin
11 December 2023 21:49
17
Yes, that is the problem. You have something very wrong with your DNS.
What is in /etc/dhcpcd.conf? Watch the spelling, it is not dhcpd.conf or anything else similar.
nx2i
11 December 2023 23:04
18
I had set a static IP for this host in the past using /etc/dhcpd.conf. I eliminated these few lines from the file to allow the router to set the IP. After rebooting both the router and Pi 4 host. I checked the IP; it has changed to a new LAN IP, like you'd expect. Internet connectivity seems fine. However I still get the wrong IP when trying to connect to deb.nodesource.com :
--2023-12-11 17:59:26-- https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease
2023-12-11 17:59:27 ERROR 503: Service Unavailable.
Server: 192.168.1.1
Address: 192.168.1.1#53
jbudd
11 December 2023 23:35
19
That's the same as on my Raspberry Pi running PiHole
pi@GlassPi:~ $ nslookup deb.nodesource.com
Server: 127.0.0.1
Address: 127.0.0.1#53
But wget works
--2023-12-11 23:31:13-- https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease
Resolving deb.nodesource.com (deb.nodesource.com)... 172.67.10.205, 104.22.5.26, 104.22.4.26, ...
Connecting to deb.nodesource.com (deb.nodesource.com)|172.67.10.205|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 12140 (12K) [binary/octet-stream]
Saving to: ‘InRelease.1’
InRelease.1 100%[==================================================================================================>] 11.86K --.-KB/s in 0.001s
2023-12-11 23:31:13 (15.8 MB/s) - ‘InRelease.1’ saved [12140/12140]
So I don't think it's a DNS error?
nx2i
12 December 2023 00:30
20
Pihole is disabled on my Pi4.
the wget commnd you show here resolves to the correct IP address for deb.nodesource.com , but my system does not. Note the output form my wget resolves to a different IP; hence the 503 error:
wget -v https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease
--2023-12-11 19:25:52-- https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease
Connecting to deb.nodesource.com (deb.nodesource.com )|143.204.15.127|:443. .. connected.
2023-12-11 19:25:53 ERROR 503: Service Unavailable.
I haven't yet figured out why this happens.
jbudd
12 December 2023 00:37
21
Yes, I see that the DNS server reported by your dig command is 208.67.222.222 while nslookup uses localhost.
Does it make a difference if you specify DNS servers in your router - 1.1.1.1 or 8.8.8.8?
