Hi, the experts of Node-Red, I am an undergraduate teacher, very new to Node-Red. I am unable to install node red on my raspberry pi. Could some one please help me. What mistake i did. Plese find the error message here:
curl https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered
curl: (28) Failed to connect to raw.githubusercontent.com port 443: Connection timed out
Hello @Jagadeesh_aditya, welcome to the forum.
It looks like you are using the right installation command
bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered) --node18
If you try again after a short wait it might work.
Otherwise, does your Raspberry Pi have access to the internet - does sudo apt update && sudo apt -y full-upgrade give any errors?
Are you trying to install over a university network?
sudo apt update gives the following
Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
Err:1 https://deb.nodesource.com/node_20.x nodistro InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
and sudo apt -y full-upgrade also giving lot of errors.
I am using my mobile hotspot and accessing the raspberry pi desktop through VNC viewer
As i cannot insert more than 2 links, i am not posting the remaining errors
Why? You would have much less troubles if you access it via SSH (far less computationally expensive than running VNC)
I dont think you ran the command @jbudd suggested. If you look at it, it has --node18 on the end, but you are seeing errors for node 20.
Before moving on to the below, I suggest you try the bash script once more, with the --node18 as JBudd posted.
Manual install:
lastly, that error is pretty well covered around the internet & most recommend you head to the nodejs repository where install instructions have improved somewhat lately: GitHub - nodesource/distributions: NodeSource Node.js Binary Distributions
Installation Instructions
Node.js
If you have root access, you can omit the 'sudo' command as you already have full administrative privileges.
- Download and import the Nodesource GPG key
sudo apt-get update sudo apt-get install -y ca-certificates curl gnupg sudo mkdir -p /etc/apt/keyrings curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
- Create deb repository
NODE_MAJOR=20 echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
Optional:
NODE_MAJORcan be changed depending on the version you need.NODE_MAJOR=16 NODE_MAJOR=18 NODE_MAJOR=20
- Run Update and Install
sudo apt-get update sudo apt-get install nodejs -y
