I'm trying to interact with the GPIOs of a Radxa Rock3A through Node-red.
Node-Red is in a Docker container.
According to what I found on the internet, node-red-contrib-libgpiod are the solution.
The requirements for these nodes are not in the prebuild NodeRED images so I compiled my own image.
Editing Dockerfile.debian, add :
apt install gpiod libgpiod-dev libgpiod-doc libnode-dev
npm i node-libgpiod
Then build the image without problem.
Setting up the container also goes smoothly
my docker compose file :
services:
node-red:
container_name: nodered_1
image: node-red-build:node-red-libgpiod
privileged: true
restart: always
environment:
- TZ=Europe/Paris
ports:
- "1880:1880"
volumes:
- node_red_data:/data
devices:
- "/dev/gpiochip0:/dev/gpiochip0:rwm"
- "/dev/gpiochip1:/dev/gpiochip1:rwm"
- "/dev/gpiochip2:/dev/gpiochip2:rwm"
- "/dev/gpiochip3:/dev/gpiochip3:rwm"
volumes:
node_red_data:
The first problem occurs when I want to install the palett "node-red-contrib-libgpiod"
2025-05-09T09:40:52.950Z Installer : node-red-contrib-libgpiod 0.0.1
2025-05-09T09:40:51.244Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-libgpiod@0.0.1
2025-05-09T09:40:54.395Z [err] npm error code EACCES
2025-05-09T09:40:54.396Z [err] npm error syscall open
2025-05-09T09:40:54.396Z [err] npm error path /data/.npm/_cacache/tmp/e68164e8
2025-05-09T09:40:54.397Z [err] npm error errno EACCES
2025-05-09T09:40:54.398Z [err] npm error
2025-05-09T09:40:54.398Z [err] npm error Your cache folder contains root-owned files, due to a bug in
2025-05-09T09:40:54.398Z [err] npm error previous versions of npm which has since been addressed.
2025-05-09T09:40:54.398Z [err] npm error To permanently fix this problem, please run:
2025-05-09T09:40:54.398Z [err] npm error sudo chown -R 1000:1000 "/data/.npm"
2025-05-09T09:40:54.403Z [err] npm error Log files were not written due to an error writing to the directory: /data/.npm/_logs
2025-05-09T09:40:54.403Z [err] npm error You can rerun the command with `--loglevel=verbose` to see the logs in your terminal
2025-05-09T09:40:54.424Z rc=1
I therefore apply the proposed solution (loged as root inside the container)
And the pallet installs correctly (Is the proposed solution correct?)
Then I place a node from this palett on the flow (ie. "GPIO in") with a correct setting like
- device : gpiochip1
- pin : 0
- name : pin-03
then I deploy the flow. This is where I have a second problem. The node indicates "Unable to open device"
If in the container console i run "gpioinfo" as root, the command return the list of the gpio in the /dev/gpiochip but the same command as user node-red return :
gpioinfo: error accessing GPIO chips: Permission denied
So the user running NodeRED (node-red) does not have rights access to peripherals.
After a long search on the internet I found a workaround, running as root :
chmod a+rw /dev/gpiochip*
Then redeploy the flow and it work ! ![]()
But there is a third problem that I have not been able to solve.
This workaround is temporary and does not survive a reboot !
How can we make this solution (or an other?) sustainable?
Thank you.
