Error in calculation function of crc-16 check code
Hi, Steve-Mcl, sorry to bother you again, I found a bug in your previous function for calculating crc16 that the last two digits of the check code will not be displayed if there are 0's in it, what do I need to do to fix this bug? Thanks again!
Clipboard 2
        "id": "12dd6725e2172907",
        "type": "function",
        "z": "434f482843cce883",
        "name": "crc16_buffer",
        "func": "function crc16(str) {\n    const buf = Buffer.from(str, 'hex')\n    let crc = 0xFFFF;\n    for (let i = 0; i < buf.length; i++) {\n        crc = crc ^ buf[i];\n        for (let j = 0; j < 8; j++) {\n            const temp = crc & 0x01;\n            crc >>= 0x01;\n            if (temp == 0x01) {\n                crc ^= 0xA001;\n            }\n        }\n    }\n    return crc;\n}\n\nconst crc = crc16(msg.payload);\nconst arr = crc.toString(16).toUpperCase().substring(-4).split(\"\");\nmsg.payload = msg.payload + arr.splice(-2).concat(arr).join(\"\");\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1630,
        "y": 1540,
                "2d38da89494f0166"
        "id": "9bf78df919110200",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "fe0500010000",
        "payloadType": "str",
        "x": 1450,
        "y": 1540,
                "12dd6725e2172907"
        "id": "2d38da89494f0166",
        "type": "debug",
        "name": "debug 11",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1800,
        "y": 1540,
    let crc = 0xFFFF;
        crc = crc ^ buf[i];
            crc >>= 0x01;
            if (temp == 0x01) {
                crc ^= 0xA001;
    return crc;
const arr = crc.toString(16).toUpperCase().substring(-4).split("")
msg.payload = msg.payload + arr.splice(-2).concat(arr).join("");
Clipboard 1
The correct string should be:fe05000400009804, fe05000100008805
change this line ↑ to this ↓
const arr = crc.toString(16).padStart(4, '0').toUpperCase().substring(-4).split("")
Working Demo Flow...
[{"id":"12dd6725e2172907","type":"function","z":"1543d308b342690a","name":"crc16_buffer","func":"function crc16(str) {\n    const buf = Buffer.from(str, 'hex')\n    let crc = 0xFFFF;\n    for (let i = 0; i < buf.length; i++) {\n        crc = crc ^ buf[i];\n        for (let j = 0; j < 8; j++) {\n            const temp = crc & 0x01;\n            crc >>= 0x01;\n            if (temp == 0x01) {\n                crc ^= 0xA001;\n            }\n        }\n    }\n    return crc;\n}\n\nconst crc = crc16(msg.payload);\nconst arr = crc.toString(16).padStart(4, '0').toUpperCase().substring(-4).split(\"\");\nmsg.payload = msg.payload + arr.splice(-2).concat(arr).join(\"\");\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1350,"y":760,"wires":[["2d38da89494f0166"]]},{"id":"9bf78df919110200","type":"inject","z":"1543d308b342690a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"fe0500010000","payloadType":"str","x":1170,"y":780,"wires":[["12dd6725e2172907"]]},{"id":"2d38da89494f0166","type":"debug","z":"1543d308b342690a","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1520,"y":760,"wires":[]},{"id":"65395e103f7f3d4d","type":"inject","z":"1543d308b342690a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"fe0500040000","payloadType":"str","x":1170,"y":740,"wires":[["12dd6725e2172907"]]}]
After testing, the results have been completely correct, thanks again for your selfless help!
