I don't understand where is the error ...
Can you help me?
windCardinal is a const var
if (windSpeed > 2)
switch (windCardinal)
case "NE":
output[8] = { label: "GRECALE" }
break;
case "N":
output[8] = { label: "TRAMONTANA" }
break;
case "E":
output[8] = { label: "LEVANTE" }
break;
case "SE":
output[8] = { label: "SCIROCCO" }
break;
case "S":
output[8] = { label: "OSTRO" }
break;
case "O":
output[8] = { label: "PONENTE" }
break;
case "SO":
output[8] = { label: "LIBECCIO" }
break;
case "NO":
output[8] = { label: "MAESTRALE" }
break;
default:
output[8] = { label: "-" }
else
If I delete case "O", "SO", "NO" I have no error .....
jbudd
3 April 2023 11:49
2
What does the editor show when you put the cursor over "O" ?
What else is in the function (that looks like a fragment and as it stands, there is no error - but other parts of the function may shed some light)
My guess would be windCardinal is a typed variable or set in your code above to every value except "O", "SO" & "NO" - therefore complaining because the values "O", "SO" & "NO" are impossible & pointless.
Well I fix the problem ....
The var windCardinal derives from this function:
let degreesToCardinal = function (deg) {
if (deg > 11.25 && deg <= 33.75) { return "NNE"; }
else if (deg > 33.75 && deg < 56.25) { return "NE"; }
else if (deg > 56.25 && deg < 78.75) { return "ENE"; }
else if (deg > 78.75 && deg < 101.25) { return "E"; }
else if (deg > 101.25 && deg < 123.75) { return "ESE"; }
else if (deg > 123.75 && deg < 146.25) { return "SE"; }
else if (deg > 146.25 && deg < 168.75) { return "SSE"; }
else if (deg > 168.75 && deg < 191.25) { return "S"; }
else if (deg > 191.25 && deg < 213.75) { return "SSW"; }
else if (deg > 213.75 && deg < 236.25) { return "SW"; }
else if (deg > 236.25 && deg < 258.75) { return "WSW"; }
else if (deg > 258.75 && deg < 281.25) { return "W"; }
else if (deg > 281.25 && deg < 303.75) { return "WNW"; }
else if (deg > 303.75 && deg < 326.25) { return "NW"; }
else if (deg > 326.25 && deg < 348.75) { return "NNW"; }
else { return "N"; }
const windSpeed = Number(msg.payload.current.wind_speed.toFixed(1));
const windCardinal = degreesToCardinal(msg.payload.current.wind_deg);
and case "O", "SO", "NO" are not in that list.
Sorry, I am no longer young and sometimes I lose myself .....
So the Function Node Editor KNOWS that the function will never return "O", "SO" or "NO"
Like I said ↓
So how did you fix this. Did you add "O", "SO" & "NO" as possible return values OR did you remove "O", "SO" & "NO" cases?
I replace "O" with "W" in the case selection
