Error installing an modbus-extension
Hello, I wanted to install a modbus server, but I keep getting an error message. Can someone tell me where the problem is or if something else needs to be installed?
i use windows 10 with io-broker and node-red.
node-red-contrib-modbus-api 0.3.0
Summary
2023-01-29T19:03:59.257Z Installieren : node-red-contrib-modbus-api 0.3.0
2023-01-29T19:03:59.577Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-modbus-api@0.3.0
2023-01-29T19:04:00.453Z [err] npm
2023-01-29T19:04:00.454Z [err] WARN config global --global, --local are deprecated. Use --location=global instead.
2023-01-29T19:04:01.223Z [err] npm
2023-01-29T19:04:01.224Z [err]
2023-01-29T19:04:01.224Z [err] WARN config production Use --omit=dev instead.
2023-01-29T19:04:11.430Z [err] npm
2023-01-29T19:04:11.430Z [err] ERR! code 1
2023-01-29T19:04:11.430Z [err] ERR! path C:\Program Files\ioBroker\node_modules\iobroker.node-red\userdata\node_modules@serialport\bindings
2023-01-29T19:04:11.432Z [err] npm ERR! command failed
2023-01-29T19:04:11.432Z [err] npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2023-01-29T19:04:11.432Z [err] ERR! gyp info it worked if it ends with ok
2023-01-29T19:04:11.432Z [err] npm ERR! gyp info using node-gyp@9.0.0
2023-01-29T19:04:11.432Z [err] npm ERR! gyp info using node@16.15.1 | win32 | x64
2023-01-29T19:04:11.432Z [err] ERR! gyp ERR! find Python
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python Python is not set from command line or npm configuration
2023-01-29T19:04:11.433Z [err] npm
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python Python is not set from environment variable PYTHON
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python checking if "python3" can be used
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python - "python3" is not in PATH or produced an error
2023-01-29T19:04:11.433Z [err] npm ERR!
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python checking if "python" can be used
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python - "python" is not in PATH or produced an error
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exe
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37\python.exe
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python checking if Python is C:\Program Files\Python37\python.exe
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python - "C:\Program Files\Python37\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37-32\python.exe
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37-32\python.exe" could not be run
2023-01-29T19:04:11.433Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python37-32\python.exe
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python - "C:\Program Files\Python37-32\python.exe" could not be run
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python37-32\python.exe
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python - "C:\Program Files (x86)\Python37-32\python.exe" could not be run
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36\python.exe
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36\python.exe" could not be run
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python checking if Python is C:\Program Files\Python36\python.exe
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python - "C:\Program Files\Python36\python.exe" could not be run
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe" could not be run
2023-01-29T19:04:11.434Z [err] ERR! gyp ERR! find Python checking if Python is C:\Program Files\Python36-32\python.exe
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python - "C:\Program Files\Python36-32\python.exe" could not be run
2023-01-29T19:04:11.434Z [err] ERR! gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python36-32\python.exe
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python - "C:\Program Files (x86)\Python36-32\python.exe" could not be run
2023-01-29T19:04:11.434Z [err] ERR! gyp ERR! find Python checking if the py launcher can be used to find Python 3
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python - "py.exe" is not in PATH or produced an error
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python **********************************************************
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python You need to install the latest version of Python.
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python you can try one of the following options:
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python (accepted by both node-gyp and npm)
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python - Set the environment variable PYTHON
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python - Set the npm configuration variable python:
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
2023-01-29T19:04:11.434Z [err] ERR! gyp ERR! find Python For more information consult the documentation at:
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python GitHub - nodejs/node-gyp: Node.js native addon build tool
2023-01-29T19:04:11.434Z [err] gyp ERR! find Python **********************************************************
2023-01-29T19:04:11.434Z [err] ERR! gyp ERR! configure error
2023-01-29T19:04:11.434Z [err] ERR! gyp ERR! stack Error: Could not find any Python installation to use
2023-01-29T19:04:11.434Z [err] gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:330:47)
2023-01-29T19:04:11.434Z [err] ERR! gyp ERR! stack at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:159:21)
2023-01-29T19:04:11.434Z [err] gyp ERR! stack at PythonFinder. (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:228:18)
2023-01-29T19:04:11.434Z [err] gyp ERR! stack at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:294:16)
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! stack at exithandler (node:child_process:406:5)
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! stack at ChildProcess.errorhandler (node:child_process:418:5)
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:527:28)
2023-01-29T19:04:11.434Z [err] gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:289:12)
2023-01-29T19:04:11.434Z [err] gyp ERR! stack at onErrorNT (node:internal/child_process:478:16)
2023-01-29T19:04:11.434Z [err] npm ERR! gyp ERR! stack at processTicksAndRejections (node:internal/process/task_queues:83:21)
2023-01-29T19:04:11.435Z [err] npm ERR! gyp ERR! System Windows_NT 10.0.19045
2023-01-29T19:04:11.435Z [err] ERR! gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
2023-01-29T19:04:11.435Z [err] gyp ERR! cwd C:\Program Files\ioBroker\node_modules\iobroker.node-red\userdata\node_modules@serialport\bindings
2023-01-29T19:04:11.435Z [err] npm ERR! gyp ERR! node -v v16.15.1
2023-01-29T19:04:11.435Z [err] npm ERR! gyp ERR! node-gyp -v v9.0.0
2023-01-29T19:04:11.435Z [err] ERR! gyp ERR! not ok
2023-01-29T19:04:11.436Z [err]
2023-01-29T19:04:11.436Z [err] npm
2023-01-29T19:04:11.436Z [err] ERR! A complete log of this run can be found in:
2023-01-29T19:04:11.436Z [err] npm ERR!
2023-01-29T19:04:11.436Z [err] C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache_logs\2023-01-29T19_04_01_188Z-debug-0.log
2023-01-29T19:04:11.453Z rc=1
Hi @spunky1a
Welcome to the forums.
The module you are installing, requires the serialport package.
this package needs 'building' - as its a native binary.
This requires python to be installed, but the build process cannot find python.
The suggestion is to install python 3.8 for Windows to allow the build process to complete.
ok thanks, i reinstalled python, the path wasn't set correctly, now it works :grinning:
