Hi i tried installing PCA9856 node but it needs i2c-bus and have this errors
pi@raspberrypi:~ $ sudo npm install -g i2c-bus
i2c-bus@4.0.9 install /usr/lib/node_modules/i2c-bus
node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.15.3"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/usr/lib/node_modules/i2c-bus/build'
gyp ERR! System Linux 4.14.98-v7+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/lib/node_modules/i2c-bus
gyp ERR! node -v v10.15.3
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! i2c-bus@4.0.9 install: node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the i2c-bus@4.0.9 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /root/.npm/_logs/2019-04-06T16_13_22_138Z-debug.log
how do i resolve this?
Thank you
