Hello guys any body use Node-Red with docker ?
Let me explain the aplication:
I use docker compose and set the network, ip (fixed) and volume (outside) using the docker-compose. After run docker compose, I run to inside of container e execute npm install of all modules. So I do the flows that are been saved in the volume outside/inside :data.
But for any one reason, after remove the container e run a new docker-compose, the message of image apear and no one flow work again.
I try diferent options but all with same result Error: node not deplyed
- import the flows.json (Error)
- copy and past the file flows.json in the volume (Error)
Exist some other file that I should be import?
