Error opening node red in cmd
I am not able to open node red, I am using node red since 2 weeks.but, this error is contineously running in command promt when I type node-red to start node red.
9 Sep 11:58:12 - [error] [opc-da server:c97c3198.e3a6] Error: 4112 - Unknown error!
9 Sep 11:58:12 - [warn] [opc-da server:c97c3198.e3a6] Trying to reconnect...
Please help somone what to get rid of this error
Vishal
The error is coming from an opc-da server node you have in your flows.
You need to either fix the configuration of that node or, if you don't want it, remove the node entirely. It sounds like a Config node, so open up the Configuration Nodes sidebar and search for it in there.
Thanks for reply
but,I am not able to open the node red. because in cmd only this error is keep on occuring.
How can I stop this error in cmd and open node red ?
if there any way to delete this from library from node red, please tell
Vishal
If you run
node-red --safe
it will start the editor but not run the flows. If that doesn't work then please post the full startup log here. Use the </> button when pasting it in.
Thanks, bur I already uninstalled and then reinsatlled the node red . Though I had my flows, there are lot of changes I had to do with respect to UI and even many graphs are not working . I am still doing changes.
Earlier I was using OPCUa read , now its not working I have to use subscrible to read the data and now sampling rate is very slow 6-7 data per second with subscribe in OPCUa. with another OPCUA node for another controller, read is working, so I am little confused.
Vishal
