Since my company considers using the Revolution Pi Connect in the future, I tried deploying our current flow on this hardware.
I've set up Node-RED by following the steps outlined in the installation guide, then loaded our project (after adjusting the settings file accordingly, of course) and installed the dependencies following Node-RED's complaints. Among these dependencies is the Modbus package, which installs, but keeps some nodes, notably flex-getters (which are used, among others, in our flow) disabled. I get some warnings displayed in the browser, but the node-red-log seems clean.
Running my browser from a terminal, I get the following:
** Message: console message: http://localhost:1880/red/red.min.js @16: Node-RED: 0.20.5
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-modbus/Modbus-Client] SyntaxError: Unexpected identifier 'node'
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-modbus/Modbus-Read] SyntaxError: Unexpected identifier 'nodeLabel'
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-modbus/Modbus-Getter] SyntaxError: Unexpected identifier 'tabs'
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-modbus/Modbus-Flex-Getter] SyntaxError: Unexpected identifier 'tabs'
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-modbus/Modbus-Write] SyntaxError: Unexpected identifier 'previous'
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-modbus/Modbus-Flex-Server] SyntaxError: Unexpected identifier 'node'
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-modbus/Modbus-Response-Filter] SyntaxError: Unexpected identifier 'node'
** Message: console message: http://localhost:1880/red/red.min.js @16: [node-red-contrib-play-audio/play-audio] SyntaxError: Unexpected token ')'
which matches with the warnings that get shown in the Node-RED UI. I did not get these on a regular Raspberry Pi and a Windows machine.
Any clue what the problem could be here? Could it have to do with the RevPi using a modified Raspian version with RT kernel? Or is it perhaps only a browser problem (I'm ssh-ing into the machine and inspect the flow locally in Epiphany, because at the moment there are no other browsers installed)?
