Errors related to sqlite when migrating from docker image 2.2.2-16 to 3.0.2-16
My dockerfile works fine when using image nodered/node-red:2.2.2-16 but when changing to nodered/node-red:3.0.2-16 the build failed.
FYI successful build output when using image nodered/node-red:2.2.2-16:
Step 3/16 : RUN set -ex && apk --no-cache add sudo sqlite exiftool
 ---> Running in a7b5a2da7d9e
+ apk --no-cache add sudo sqlite exiftool
fetch http://dl-cdn.alpinelinux.org/alpine/v3.12/main/x86_64/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/v3.12/community/x86_64/APKINDEX.tar.gz
(1/5) Installing perl (5.30.3-r0)
(2/5) Installing perl-image-exiftool (11.99-r0)
(3/5) Installing exiftool (11.99-r0)
(4/5) Installing sqlite (3.32.1-r1)
(5/5) Installing sudo (1.9.5p2-r0)
Executing busybox-1.31.1-r21.trigger
OK: 380 MiB in 72 packages
Removing intermediate container a7b5a2da7d9e
 ---> b4eace34d3b2
Step 4/16 : RUN echo "node-red ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers
 ---> Running in c70af9c7dc56
Removing intermediate container c70af9c7dc56
 ---> de0dbff0d2c5
Step 5/16 : RUN echo "Set disable_coredump false" >> /etc/sudo.conf
 ---> Running in 0daa37379e53
Removing intermediate container 0daa37379e53
 ---> 811b6c702f8b
Step 6/16 : RUN mkdir                   /remote
 ---> Running in 2a370ad81f5d
Removing intermediate container 2a370ad81f5d
 ---> c3c2c0023ae3
Step 7/16 : RUN chown node-red:node-red /remote
 ---> Running in 638f550fb1aa
Removing intermediate container 638f550fb1aa
 ---> acee8ab3e5d7
Step 8/16 : RUN mkdir /node-red
 ---> Running in 542e9437af2b
Removing intermediate container 542e9437af2b
 ---> 16f434b1f98d
Step 9/16 : RUN chown node-red:node-red /node-red
 ---> Running in cbdd41878fb3
Removing intermediate container cbdd41878fb3
 ---> f87df35fec0e
Step 10/16 : USER node-red
 ---> Running in d26a33a9ebc8
Removing intermediate container d26a33a9ebc8
 ---> 87d523178bc7
Step 11/16 : COPY --chown=node-red:node-red  package.json /node-red/
 ---> a8197293dad1
Step 12/16 : RUN  cd /node-red ; npm install --unsafe-perm --no-update-notifier --no-fund --only=production
 ---> Running in d1ac89dc84ce
npm WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
added 124 packages, and audited 125 packages in 4m
found 0 vulnerabilities
Removing intermediate container d1ac89dc84ce
 ---> b338b91e1b4e
Step 13/16 : COPY --chown=node-red:node-red flows.json flows_cred.json settings.js /node-red/
 ---> 0fae54f4a3ce
and this is what I get when changing to nodered/node-red:3.0.2-16
Status: Downloaded newer image for nodered/node-red:3.0.2-16
 ---> a15fc0f4e930
Step 2/16 : USER root
 ---> Running in 3991cc5234e3
Removing intermediate container 3991cc5234e3
 ---> e6be7a2e86f3
 ---> Running in a398b431ecef
fetch https://dl-cdn.alpinelinux.org/alpine/v3.16/main/x86_64/APKINDEX.tar.gz
fetch https://dl-cdn.alpinelinux.org/alpine/v3.16/community/x86_64/APKINDEX.tar.gz
(1/8) Installing perl (5.34.1-r0)
(2/8) Installing perl-image-exiftool (12.40-r0)
(3/8) Installing exiftool (12.40-r0)
(4/8) Installing perl-error (0.17029-r1)
(5/8) Installing perl-git (2.36.2-r0)
(6/8) Installing git-perl (2.36.2-r0)
(7/8) Installing sqlite (3.38.5-r0)
(8/8) Installing sudo (1.9.10-r0)
Executing busybox-1.35.0-r15.trigger
OK: 325 MiB in 77 packages
Removing intermediate container a398b431ecef
 ---> 8054e02a62e0
 ---> Running in 1830c108eda1
Removing intermediate container 1830c108eda1
 ---> ab127c044e49
 ---> Running in d9d54f105742
Removing intermediate container d9d54f105742
 ---> 7f43c60ceb3f
 ---> Running in dbff312b67ea
Removing intermediate container dbff312b67ea
 ---> ccabbbfd2908
 ---> Running in 8b360fad1950
Removing intermediate container 8b360fad1950
 ---> 05871d5b0ed8
 ---> Running in 5345facdfbcf
Removing intermediate container 5345facdfbcf
 ---> 1ffd0f505ca2
 ---> Running in 370fa48a3239
Removing intermediate container 370fa48a3239
 ---> 26056939c4d4
 ---> Running in adb981def21f
Removing intermediate container adb981def21f
 ---> 92cdc7f21d3f
 ---> 1703189f4e95
 ---> Running in 5ab17b47fca2
npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
npm ERR! code 1
npm ERR! path /node-red/node_modules/sqlite3
npm ERR! command failed
npm ERR! command sh -c node-pre-gyp install --fallback-to-build
npm ERR! make: Entering directory '/node-red/node_modules/sqlite3/build'
npm ERR!   ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3310100/sqlite3.c
npm ERR! make: Leaving directory '/node-red/node_modules/sqlite3/build'
npm ERR! Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/node-red/node_modules/sqlite3/lib/binding/node-v93-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/node-red/node_modules/sqlite3/lib/binding/node-v93-linux-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v93' (1)
npm ERR! node-pre-gyp info it worked if it ends with ok
npm ERR! node-pre-gyp info using node-pre-gyp@0.11.0
npm ERR! node-pre-gyp info using node@16.16.0 | linux | x64
npm ERR! node-pre-gyp WARN Using needle for node-pre-gyp https download
npm ERR! node-pre-gyp info check checked for "/node-red/node_modules/sqlite3/lib/binding/node-v93-linux-x64/node_sqlite3.node" (not found)
npm ERR! node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v93-linux-x64.tar.gz
npm ERR! node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v93-linux-x64.tar.gz
npm ERR! node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v93-linux-x64.tar.gz
npm ERR! node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.2.0 and node@16.16.0 (node-v93 ABI, musl) (falling back to source compile with node-gyp)
npm ERR! node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v93-linux-x64.tar.gz
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.0.0
npm ERR! gyp info using node@16.16.0 | linux | x64
npm ERR! gyp info ok
npm ERR! gyp info find Python using Python version 3.10.5 found at "/usr/bin/python3"
npm ERR! gyp http GET https://unofficial-builds.nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
npm ERR! gyp http 200 https://unofficial-builds.nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
npm ERR! gyp http GET https://unofficial-builds.nodejs.org/download/release/v16.16.0/SHASUMS256.txt
npm ERR! gyp http 200 https://unofficial-builds.nodejs.org/download/release/v16.16.0/SHASUMS256.txt
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args   'binding.gyp',
npm ERR! gyp info spawn args   '-f',
npm ERR! gyp info spawn args   'make',
npm ERR! gyp info spawn args   '-I',
npm ERR! gyp info spawn args   '/node-red/node_modules/sqlite3/build/config.gypi',
npm ERR! gyp info spawn args   '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args   '/usr/src/node-red/.cache/node-gyp/16.16.0/include/node/common.gypi',
npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
npm ERR! gyp info spawn args   '-Dvisibility=default',
npm ERR! gyp info spawn args   '-Dnode_root_dir=/usr/src/node-red/.cache/node-gyp/16.16.0',
npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
npm ERR! gyp info spawn args   '-Dnode_lib_file=/usr/src/node-red/.cache/node-gyp/16.16.0/<(target_arch)/node.lib',
npm ERR! gyp info spawn args   '-Dmodule_root_dir=/node-red/node_modules/sqlite3',
npm ERR! gyp info spawn args   '-Dnode_engine=v8',
npm ERR! gyp info spawn args   '--depth=.',
npm ERR! gyp info spawn args   '--no-parallel',
npm ERR! gyp info spawn args   '--generator-output',
npm ERR! gyp info spawn args   'build',
npm ERR! gyp info spawn args   '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! /bin/sh: python: not found
npm ERR! make: *** [deps/action_before_build.target.mk:13: Release/obj/gen/sqlite-autoconf-3310100/sqlite3.c] Error 127
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
npm ERR! gyp ERR! System Linux 5.15.0-46-generic
npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/node-red/node_modules/sqlite3/lib/binding/node-v93-linux-x64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/node-red/node_modules/sqlite3/lib/binding/node-v93-linux-x64" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v93"
npm ERR! gyp ERR! cwd /node-red/node_modules/sqlite3
npm ERR! gyp ERR! node -v v16.16.0
npm ERR! gyp ERR! node-gyp -v v9.0.0
npm ERR! gyp ERR! not ok
npm ERR! node-pre-gyp ERR! build error
npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/node-red/node_modules/sqlite3/lib/binding/node-v93-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/node-red/node_modules/sqlite3/lib/binding/node-v93-linux-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v93' (1)
npm ERR! node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/node-red/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
npm ERR! node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
npm ERR! node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1092:16)
npm ERR! node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
npm ERR! node-pre-gyp ERR! System Linux 5.15.0-46-generic
npm ERR! node-pre-gyp ERR! command "/usr/local/bin/node" "/node-red/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
npm ERR! node-pre-gyp ERR! cwd /node-red/node_modules/sqlite3
npm ERR! node-pre-gyp ERR! node -v v16.16.0
npm ERR! node-pre-gyp ERR! node-pre-gyp -v v0.11.0
npm ERR! node-pre-gyp ERR! not ok
npm ERR!     /data/.npm/_logs/2022-08-12T15_36_34_899Z-debug-0.log
1 error occurred:
        * Status: The command '/bin/sh -c cd /node-red ; npm install --unsafe-perm --no-update-notifier --no-fund --only=production' returned a non-zero code: 1, Code: 1
make: *** [all] Error 1
The problem might be due to the sqlite node.
FYI here my package.json
    "name": "node-red-mydrive-ctrl",
    "description": "Node-RED My-Drive Controller",
    "version": "0.0.1",
    "dependencies": {
        "node-red-node-daemon": "0.2.1",
        "node-red-node-sqlite": "0.6.0",
        "node-red-dashboard": "3.1.6",
        "node-red-contrib-ui-etable": "4.6.3"
    "node-red": {
        "settings": {
            "flowFile": "flows.json",
            "credentialsFile": "flows_cred.json"
and here my Dockerfile:
FROM nodered/node-red:3.0.2-16
######### Changing to root as below commands should be run as root #############
USER root
# installing sudo command & sqlite
# following commands should assure that user node-red can use sudo without requiring to enter a password.
# get rid of the sudo error (see https://github.com/sudo-project/sudo/issues/42#issuecomment-609079906)
# the WD samba shares will be mounted under folder /remote
RUN mkdir                   /remote
# creating the Node-RED userDir "/node-red" with proper permissions
RUN mkdir /node-red
######### Changing back to node-red user #####################
USER node-red
# The following command will build all the nodes specified in the package.json that is copied
# in previous command.
# Copy Node-RED flow files and settings to userDir
COPY --chown=node-red:node-red entrypoint.sh rules.json ./
# also Copy settings.js to /data folder as docker healthcheck.js is requiring this.
# see https://discourse.nodered.org/t/node-red-docker-settings-js/26529
COPY settings.js /data/
# the below entrypoint replaces the entrypoint of the nodered/node-red
ENTRYPOINT  ["bash", "entrypoint.sh"]
I am building it on an intel nuc (amd64 architecture)
That's the important bit of the error and entirely expected and mentioned in the release notes
Any reason you are trying to install node-red-node-sqlite 0.6.0 when the latest is 1.0.3?
Thanks,
Using latest version of node-red-node-sqlite (= version 1.0.3) instead of version 0.6.0 fixed it.
