Hello everybody,
I have the following script, which sends an image to the Node-Red Port every 10 seconds: XX.XX.XXX.XXX:1880/imageUpdate
I would like to receive and save the images via Node-Red logic later for further processing and image recognition logic.
ESP32CAM coding: https://hastebin.com/ejewutadoj.js
I created the flow below as a starting point.
The requests arrive somehow, but the images cannot be saved.
When I use instead of Node-Red just a simple Node.JS script with another port 8880 and post the image in that ESPCoding to that Port, the image can be correctly posted and saved.
Node-Script: https://ghostbin.com/paste/BiwjB
Does anyone have a template where pictures can be received from an ESP32Cam using the HTTP Post Request?
Is the "File" node correct when the images arrive in Node-Red, can I then save the files directly to a folder or do I need to convert them first to another format?
Its right, the HTTP image posts need to be posted to Port 1880?
in the debug section I can see the message:
<Input should be a buffer or a base64 string or a Jimp image (containing a jpg or png image)>
