Eurotronic Zigbee Spirit Thermostat in HomeKit
Hello everyone,
I am trying to model my thermostat in Homekit (the connection is working and I can control my thermostat (over deConz Addon and REST API)).
I've already had a look at the "Clever Thermostat" demo, but I can't quite figure out how to implement e.g. "Auto", "Off" and "Heat" so that I can select them in the Home App. Somehow the current (measured) temperature and the set temperature should still be included.
Currently the entries are still generated by Home-Assistant. But I want to port everything to Node-RED. I would be glad if you can give me some tips. I would be happy to share my finished flow. :slight_smile:
Do you know homebridge?
and homebridge-mqtt?
I did not know that yet, thank you! sounds quite promising ... I'll bring this up as a container :slight_smile:
Perfectly!! Better than expected :slight_smile: I instantly purged Home-Assistant
