Hello, I wanted to save the voltage data to an excel with the date and time, but they are stored in the same column, does anyone know how to separate them?
@Mariano welcome to the forum! So what have you tried so far?
If you create a small example flow that reproduces your issue and export it and paste it to a reply, it will make it easier for someone to help you.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
Thanks for your time, I leave you my code so you can see it. ![]()
"id": "04c3f6fabe43a461",
"type": "function",
"z": "8f292025fe253f81",
"name": "Datos",
"func": "var d= new Date ();\nvar time= d.toLocaleTimeString();\nvar s= {'time':time,'sepam':sepam};\nvar sepam=msg.payloand\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 330,
"y": 300,
"2962396ed51da88c"
"id": "8a0cffa84df7cbc8",
"type": "function",
"name": "fecha excel",
"func": "var d = new Date()\nvar date = d.getFullYear()+\"/\"+(d.getMonth()+1)+\"/\"+d.getDate()+\" \"+d.getHours()+\":\"+d.getMinutes()+\":\"+d.getSeconds();\nmsg.payload = date\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 350,
"y": 260,
"2962396ed51da88c"
"id": "ced8e6d520d9bc24",
"type": "debug",
"name": "lectura",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 870,
"y": 280,
"id": "2962396ed51da88c",
"type": "file",
"filename": "C:\\Lectura de datos\\Registro de datos.csv",
"filenameType": "str",
"appendNewline": true,
"createDir": false,
"overwriteFile": "false",
"encoding": "none",
"x": 640,
"y": 280,
"ced8e6d520d9bc24"
"id": "ada1cccb4917558c",
"type": "modbus-read",
"name": "Sepam",
"topic": "",
"showStatusActivities": false,
"logIOActivities": false,
"showErrors": false,
"unitid": "",
"dataType": "HoldingRegister",
"adr": "286",
"quantity": "1",
"rate": "10",
"rateUnit": "s",
"delayOnStart": false,
"startDelayTime": "",
"server": "d91e649d.344078",
"useIOFile": false,
"ioFile": "",
"useIOForPayload": false,
"emptyMsgOnFail": false,
"x": 130,
"y": 280,
"8a0cffa84df7cbc8",
"04c3f6fabe43a461"
"id": "d91e649d.344078",
"type": "modbus-client",
"name": "Medidor",
"clienttype": "tcp",
"bufferCommands": true,
"stateLogEnabled": false,
"queueLogEnabled": false,
"failureLogEnabled": false,
"tcpHost": "192.168.0.87",
"tcpPort": "502",
"tcpType": "DEFAULT",
"serialPort": "/dev/ttyUSB",
"serialType": "RTU-BUFFERD",
"serialBaudrate": "9600",
"serialDatabits": "8",
"serialStopbits": "1",
"serialParity": "none",
"serialConnectionDelay": "100",
"serialAsciiResponseStartDelimiter": "",
"unit_id": "1",
"commandDelay": "1",
"clientTimeout": "500",
"reconnectOnTimeout": false,
"reconnectTimeout": "500",
"parallelUnitIdsAllowed": true
I already tried to unite everything in the same function but I got an error
I am unable to import your flow.
You need to follow the instructions that @zenofmud posted above.
I suspect you did not use the three back ticks ```
- you did not post your code in a format that makes it importable - did you read the directions I posted?
- You did not create a flow with any input data that demonstrated the problem.
- why do you have two function nodes processing the data? the will each send a seperate msg to the file-write node. If you want the data on the same line you will need a
joinnode or combine the twofunctionnodes into one. - your 'Datos'
functiondoes nothing, it gets a msg in and then sends the same msg out without changing the msg at all,
