Hello ,
i have problem whit how can i display data from EXCEL in real time to node red and build an dashboard ??
how can i show data from Excel in node red
Hello ,
Hi Hicham,
Can you explain a bit more, you have a spreadsheet, and you'd like to load data from it and display it in a dashboard? Do you need to just read the file, or edit/save to it as well?
For displaying tables on the node-red-dashboard, take a look at node-red-node-ui-table: https://flows.nodered.org/node/node-red-node-ui-table
If you search the flows library, you can see there's a node to load and read data from excel files, have you tried that one yet? https://flows.nodered.org/node/node-red-contrib-spreadsheet-in
thank you so much Afelix,
yea I want to write data in Excel file and at the same time be displayed in a dashboard in node red
How real time is real time? Because keep in mind that in order to display it, the file needs to be saved in Excel first. After all, it doesn't exist in the file yet if it isn't saved in Excel prior to it.
Also, are you by chance working on the same school project as Send data from excel to dashboard?
You should note that Excel uses a complex file format that is absolutely NOT suitable for real-time display. Even when using Microsoft's Office 365 cloud service, you don't actually get real-time updates of data (despite Microsoft claiming you do). Microsoft actually "cheat", you don't see updates until the file is saved on both ends.
If you want something that works in near real-time, Google docs is the way to go. But better by far would be to use a data engine that supports publish/subscribe (pub/sub).
So as Lena say's - what do you mean by "real time"?
This is the third topic in only a couple weeks where inputting data in excel, then reading it in node-red (preferably without having to save the file). Where google spreadsheets offers a kind of real time display/editing, Excel is not suitable for it.
It certainly does look like a college exercise.
I'll provide some clues as to how i would attempt this...
Set hReq = CreateObject("MSXML2.XMLHTTP"))Sub Worksheet_Change)I think that'll be as close to real time as you'll get.
