Excel xlsx export library
Hi, i am looking for a library to export things to an xlsx file. I already tried some libraries, but at all of them you can´t skip cells. For example after Inject1 i want "test1" in cell1. After this, the flow forgets the information which is in cell1, but i know that i need to write the next value after inject2 in cell2 afterwards.
All libraries i tried, the flow needed to save the informations from every cell, i couldn´t skip existing cells.
Does anyone know a xlsx library, where i can tell information xy goes to cell x? Otherwise i would need to write everything in a database first and then export the whole database to xlsx. But i want to cyclic add information in an existing xlsx file.
Thanks, Stephan
You cannot do this the way you describe. Saving an Excel file, by definition, saves whatever is in the file at time of save.
You have a couple of choices. Either manage the data in a JavaScript object (e.g. an array of objects where each inner object is a set of column-name/value pairs which is directly mappable to an Excel sheet) and make sure that object contains the right data and time of save to file.
Or, use a library that allows direct manipulation of Excel cells.
I think you misunderstood me. Saving is not the problem. I could save after each array of information. But the xlsx libraries i found fill the cells from begin.
I‘d need a library where i can fill specific cells, for example a12 to f12, then save and close and after next inject fill array in a13 to f13, save, close. Next inject: open file, fill array in a14 to f14, save, close and so on.
This looks like it might do what you want. I've not tried it though.
I think this might work as well:
There are hundreds of other node.js libraries on npmjs most of which should work with Node-RED with a bit of work.
I also need save data with xlsx file.can U tell me which node you use to save data with xlsx formate.
@TotallyInformation thanks, this is exactly what i was looking for!
