Npm xlsx how to write msg.payload to xls file
I am working npm xlsx and want to create a xlsx file on my local device from the json output. I have gotten npm xlsx to load and I am using an example I found online to test. I get nothing when I run the function.
let XLSX = global.get('xlsx')
/* original data */
var data = [
    { "name": "John", "city": "Seattle" },
    { "name": "Mike", "city": "Los Angeles" },
    { "name": "Zach", "city": "New York" }
/* this line is only needed if you are not adding a script tag reference */
if (typeof XLSX == 'undefined') XLSX = require('xlsx');
/* make the worksheet */
var ws = XLSX.utils.json_to_sheet(data);
/* add to workbook */
var wb = XLSX.utils.book_new();
XLSX.utils.book_append_sheet(wb, ws, "People");
/* write workbook */
XLSX.write(wb, { bookType: 'xlsx', type: 'buffer' });
Here is the output from the global.get('xlsx')
see flow below. thanks
[{"id":"c0fe6321df5e43c0","type":"inject","z":"6aa33e2ddb33f623","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":100,"y":220,"wires":[["bcba72236e7aca66"]]},{"id":"bcba72236e7aca66","type":"function","z":"6aa33e2ddb33f623","name":"function 1","func":"let XLSX = global.get('xlsx')\n\n/* original data */\nvar data = [\n    { \"name\": \"John\", \"city\": \"Seattle\" },\n    { \"name\": \"Mike\", \"city\": \"Los Angeles\" },\n    { \"name\": \"Zach\", \"city\": \"New York\" }\n];\n\n/* this line is only needed if you are not adding a script tag reference */\nif (typeof XLSX == 'undefined') XLSX = require('xlsx');\n\n/* make the worksheet */\nvar ws = XLSX.utils.json_to_sheet(data);\n\n/* add to workbook */\nvar wb = XLSX.utils.book_new();\nXLSX.utils.book_append_sheet(wb, ws, \"People\");\n\n/* write workbook */\nXLSX.write(wb, { bookType: 'xlsx', type: 'buffer' });\n\n\n\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"xlsx","module":"xlsx"}],"x":260,"y":220,"wires":[["c29b1f5edf30cbb8"]]},{"id":"c29b1f5edf30cbb8","type":"debug","z":"6aa33e2ddb33f623","name":"debug 1","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":430,"y":220,"wires":[]}]
I found another example that I was able to make work...
I had to add npm path and axios for the example. Now I need to take this and make it work with json to autoformat the spreadsheet. I also tried using the Windows env %USERPROFILE% for the path, but Node-RED could not interpret the env.
Regards
// Uncomment the next line for use in NodeJS:
const XLSX = global.get("xlsx");
path = global.get('path');
axios = global.get("axios");
const dirname = '/users/w8beu/downloads';
const filePath = path.join(dirname, 'Presidents.xlsx');
//const filePath = 'Presidents.xlsx';
(async() => {
  /* fetch JSON data and parse */
  const url = "https://theunitedstates.io/congress-legislators/executive.json";
  const raw_data = (await axios(url, {responseType: "json"})).data;
  /* filter for the Presidents */
  const prez = raw_data.filter(row => row.terms.some(term => term.type === "prez"));
  /* flatten objects */
  const rows = prez.map(row => ({
    name: row.name.first + " " + row.name.last,
    birthday: row.bio.birthday
  /* generate worksheet and workbook */
  const worksheet = XLSX.utils.json_to_sheet(rows);
  const workbook = XLSX.utils.book_new();
  XLSX.utils.book_append_sheet(workbook, worksheet, "Dates");
  /* fix headers */
  XLSX.utils.sheet_add_aoa(worksheet, [["Name", "Birthday"]], { origin: "A1" });
  /* calculate column width */
  const max_width = rows.reduce((w, r) => Math.max(w, r.name.length), 10);
  worksheet["!cols"] = [ { wch: max_width } ];
  /* create an XLSX file and try to save to Presidents.xlsx */
  XLSX.writeFile(workbook, filePath);
[{"id":"2e057019a22821dd","type":"inject","z":"6aa33e2ddb33f623","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":560,"wires":[["495203fdbfc3e26d"]]},{"id":"495203fdbfc3e26d","type":"function","z":"6aa33e2ddb33f623","name":"XLS-writeFile Example","func":"// Uncomment the next line for use in NodeJS:\nconst XLSX = global.get(\"xlsx\");\npath = global.get('path');\naxios = global.get(\"axios\");\nconst dirname = '/users/w8beu/downloads/';\nconst filePath = path.join(dirname, 'Presidents.xlsx');\n//const filePath = 'Presidents.xlsx';\n\n(async() => {\n  /* fetch JSON data and parse */\n  const url = \"https://theunitedstates.io/congress-legislators/executive.json\";\n  const raw_data = (await axios(url, {responseType: \"json\"})).data;\n\n  /* filter for the Presidents */\n  const prez = raw_data.filter(row => row.terms.some(term => term.type === \"prez\"));\n\n  /* flatten objects */\n  const rows = prez.map(row => ({\n    name: row.name.first + \" \" + row.name.last,\n    birthday: row.bio.birthday\n  }));\n\n  /* generate worksheet and workbook */\n  const worksheet = XLSX.utils.json_to_sheet(rows);\n  const workbook = XLSX.utils.book_new();\n  XLSX.utils.book_append_sheet(workbook, worksheet, \"Dates\");\n\n  /* fix headers */\n  XLSX.utils.sheet_add_aoa(worksheet, [[\"Name\", \"Birthday\"]], { origin: \"A1\" });\n\n  /* calculate column width */\n  const max_width = rows.reduce((w, r) => Math.max(w, r.name.length), 10);\n  worksheet[\"!cols\"] = [ { wch: max_width } ];\n\n  /* create an XLSX file and try to save to Presidents.xlsx */\n  XLSX.writeFile(workbook, filePath);\n})();","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"xlsx","module":"xlsx"},{"var":"axios","module":"axios"},{"var":"path","module":"path"}],"x":400,"y":560,"wires":[[]]}]
Would be nice to supply the example. as others may be looking at this topic as it is marked as a solution, but there is no solution shown. The forum is about sharing and helping each other after all.
Ok so here is the example that shows how to use npm xlsx to export json to xlsx file.
const XLSX = global.get('xlsx')
const filePath = path.join(dirname, 'names.xlsx');
/* original data */
var data = [
// if (typeof XLSX == 'undefined') XLSX = require('xlsx');
 XLSX.utils.book_append_sheet(wb, ws, 'People');
// XLSX.write(wb, { bookType: 'xlsx', type: 'buffer' });
XLSX.writeFile(wb, filePath )
return {payload: wb}
Here is the function node
[{"id":"0f03281575e68c43","type":"function","z":"6aa33e2ddb33f623","name":"function 1","func":"const XLSX = global.get('xlsx')\nconst dirname = '/users/w8beu/downloads';\nconst filePath = path.join(dirname, 'names.xlsx');\n\n\n/* original data */\nvar data = [\n    { \"name\": \"John\", \"city\": \"Seattle\" },\n    { \"name\": \"Mike\", \"city\": \"Los Angeles\" },\n    { \"name\": \"Zach\", \"city\": \"New York\" }\n];\n\n/* this line is only needed if you are not adding a script tag reference */\n// if (typeof XLSX == 'undefined') XLSX = require('xlsx');\n\n/* make the worksheet */\nvar ws = XLSX.utils.json_to_sheet(data);\n\n/* add to workbook */\n var wb = XLSX.utils.book_new();\n XLSX.utils.book_append_sheet(wb, ws, 'People');\n\n/* write workbook */\n// XLSX.write(wb, { bookType: 'xlsx', type: 'buffer' });\nXLSX.writeFile(wb, filePath )\nreturn {payload: wb}\n\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"xlsx","module":"xlsx"},{"var":"path","module":"path"}],"x":320,"y":180,"wires":[["c29b1f5edf30cbb8"]]}]
