I am using this fairly new node xlsx to json node, the idea of the flow is to load a file, to something with the data, and have the capability of opening a different file to repeat the process
the problem here is that once the node is used, with a certain file, for example file 1, on the next run, trying to load file 2, it will still open file 1, even when the msg.filepath input has been properly changed.
I think this is something to do with the node itself, unfortunately I cannot seem to find the place to locate the particular contributor, to provide feedback.
"id": "3e06b3433b7a20ad",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": "",
"env": []
"id": "d3e2d31e4bca1883",
"type": "inject",
"z": "3e06b3433b7a20ad",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 120,
"y": 120,
"195eb091a12ec3eb"
"id": "195eb091a12ec3eb",
"type": "change",
"rules": [
"t": "set",
"p": "filepath",
"pt": "msg",
"to": "Procedure_filepath",
"tot": "global"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 360,
"y": 120,
"8970825e3063a997"
"id": "912504b8ae2aeb06",
"type": "change",
"rules": [
"t": "set",
"p": "Procedure_Selected",
"pt": "global",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 830,
"y": 120,
"565fa3687b2cd82d"
"id": "565fa3687b2cd82d",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1090,
"y": 100,
"id": "8970825e3063a997",
"type": "XLSX-to-json",
"name": "xlsx to json",
"filepath": "msg.filepath",
"rangecell": "",
"columnkey": "",
"sheet": "",
"x": 570,
"y": 180,
"912504b8ae2aeb06"
