You haven't included the flush command.
It does seem that something is badly broken between the exec node and Python 2.7.
I tested on a Pi running RPiOS Buster. but the OP says the same happens on Windows.
Flushing stdout makes no difference, nor does substantially reducing the size of the output.
I don't see the same problem if I change the exec node to call python3. (As @Colin says, the script #! line is ignored.)
@Lupin_III if you are on a Raspberry Pi , why do you have to use python 2?
Did you add the flush and remove the -u? That is working perfectly for me on a pi running Buster.
That is odd. What does python --version show?
python 2.7.16
But on that Pi, python3 is 3.7.3 and imho python3 should always be specified
On newly installed RpiOS 64 bit, python --version gives 3.9.2
I agree with you about python 3. We wait to hear why python 2 must be used here.
I have the same version of python 2, the same OS, but for me, with the flush and without -u it works perfectly. Strange.
@jbudd are you using node-red 3.0.2? Which version of nodejs?
Yes 3.0.2, node -v gives 16.19.0
I assume you mean node 16.19.0, which is the same as I am, so it isn't that.
Don't forget that at the end of the day it is all running on a multi-tasking OS - so the process can yield to another and decide to send the buffer when it needs to - it doesn't have to wait for a flush.
Worst case you will have to rebuild the lines once they arrive in Node-RED. I "think" - (as in not done it for a while) that the split node does actually buffer things up until it sees the split character - so that may help (assuming there is always a charater to reliably split on.
It does seem more reliable for a short message at least if you flush before and after printing.
Not tried with Colin's long message.
Magic, I didn't realise it would do that.
@Lupin_III you can go back to your original flow, without the flush and with -u, and feed that into a Split node configured like this
That will then handle the stream of messages, join them, and then split on the newline.
Thanks to all. For the very nexrt days I won't be able to make other test.
Any way, just a couple of quick update:
- Unfortunatly at the moment I have to use python 2 because the script needs some important adjustment in order to make it working on python 3. At the moment these changing are not feasable and the script is quite complex.
- The best workaround I've found is to print iin python as json, like
a=[-402.17, 10.16, 17.2, 3482.43, ..........]
mydata = {
"details" : a
print(json.dumps(mydata))
in this way, but only putting -u paramiter within the exec node, the message is always sent in a unique msg payload.Sometimes a special character for a new line is happened at the end (not always). But it is something easy enough to manage.
