Explanation of code help
@cymplecy posted this code back in January
if (msg.payload == 1) {
    context.set("previousState",!context.get("previousState"))
    msg.payload = 1 * context.get("previousState");
I have used this a number of times now and spent the better part of a day googling as to how it worked. I figure if I'm going to use a lot I should understand it. Unfortunately, my google searches all point back to the forum so I am left with no explanation. If someone could please tell me what is happening I would appreciate it.
So what happens is the following, if msg.payload == 1.
in the first line:
First you get previousState variable from the node context. The content of the is negated by ! - so you have instead of true, false or vice versa. So it acts like a toggle switch. The opposite value is then immediately stored again in the node-context.
The next line:
As boolean true evaluates to 1 and false to 0 the result is 0 or 1.
To be honest I think the code is in my opinion a little bit laborious.
In my opinion it would be sufficient to use only booleans.
Thanks for the help
