Trouble with javascript
Hi, trying to change msg.payload from true to on and false to off from the alexa node. Used a function node with the following but it doesnt work, can anyone tell me why.??
if (msg.payload == "true"){
msg.payload = "on";
else if (msg.payload == "false"){
msg.payload = "off";
if its a typeof boolean true and false you need to do the comparison without the “”,so:
if (msg.payload == true) {
otherwise your looking for the literal strings of true and false.
You can see which it is when you connect a debug to the previous node and check in the debug tab for the format of this message property.
Johannes
Ps: and a happy forum anniversary :tada:
or
msg.payload = (msg.payload == true) ? "on" : "off";
or even
msg.payload = msg.payload ? "on" : "off"
You don't need to test msg.payload == true as it is itself true (or false).
That all depends on whether you wish ON when the payload is {}.
Problem solved. Thank you to everyone who helped, very much appreciated.
If you want to test for exactly true rather than just truthy then you should use ===. With == you will see a yellow warning triangle in the editor.
As i said it depends what you require.
