Function node Test whether a value is boolean or not
It's getting late and I'm having a brain freeze.
I have a payload which is either boolean true or false. However, sometimes the request times out and an error code is returned as payload which is a negative integer. I'm trying to write a one line if clause in my function node to process the boolean value but not enter the clause if the value is non-integer.
I think
if (msg.payload == true || msg.payload == false) // value is boolean
do some processing
// the evaluation of true or false failed and the processing did not happen
should work but is there a way of doing something like:
if (msg.payload || !msg.payload) // value is boolean
do some processing
to evaluate the payload as true or false?
Not explaining to well, but any help would be appreciated. Ta
Just use a switch node ?
How about?
if ("boolean" === typeof msg.payload) {  // value is boolean
You can also use typeof to check if a value is a number. MDN is helpful here.
Thanks for the prompt reply. I'm trying to use a function node as there are quite a few things I need to process, but thanks anyway.
Code to test for Boolean or number. Perfect. Thanks.
That would have worked if you had used triple =
if (msg.payload === true || msg.payload === false)
That tells javascript to test for exactly those values. Otherwise it will do type conversion to test it.
