Why is the result always false?
why is the output always false instead of true, as it is defined?
var CO2 = msg.payload;
var L1 = {
  payload: {
    On:  msg.payload.On === true}}
var L2 = {
  payload: {
var L3 = {
  payload: {
var L4 = {
  payload: {
if (CO2 > 1600){
    return [null, null, L4];
else if (CO2 > 1200){
    return [null, L3, null];
else if (CO2 < 650){
    return [L2, null, null];
Debug Output:
msg.payload : Object
object
On: false
Thanks for helping!
I see a couple potential issues here -- but without some sample input data, it's just a guess...
Using the triple equal operator forces JS to compare both the value and datatype for equality. So if you expect the output should be true, then I suspect your incoming value is the string "true", not a boolean. If you use the more forgiving == operator, then you may get what you expect.
In the previous code you are trying to access the field payload.On which means your payload is an Object, not a number. So you cannot compare any object to a number and get a truthy value.
Also, if you click onobject in the debug pane it will expand it so you can see what is there.
you pointed me to the solution. I wanted to set the msg.payload.On to true. So a simple "=" solved it...
Thank you very much!
