Currently, it is only possible to undo changes until the last deployment.
It would be nice, if this limit could be extended.
Another possibility would be the support of tab-wise snapshots.
Use case: trying something with many changes and/or deployments.
Take a look at the projects feature...
Thanks, i'm aware of the project feature - but it's a little more complicated than pressing "Ctrl-Z"
Sure, i could also copy the tab and disable the original, but the easiest way are a few keystrokes to restore the old state.
But equally, why would we implement a parallel system that duplicated what projects can do, but without the same level of functionality?
I think there is a place for a more simplified user experience with projects - something I posted back in January: Feedback wanted: Simplified git workflow
If the simplified workflow runs completely local without the usual project overhead, it sounds like a good idea!
What do you define the 'usual project overhead' as?
Projects can run completely locally already. There is no requirement to have a remote repository.
- username / password
- naming and definition of the project
- naming of commit msgs
All this should be autogenerated / filled.
If you only have a local project with no remote, there is no username/password.
You need to create a project to get started. It's a 10 second task to give it a name. Sorry, I don't think that's overhead - it's a quick one off task needed to get the benefits projects bring.
See the thread I linked to regarding commit messages. If you have any suggestions as to how those auto-filled commit messages could be made useful, I'd appreciate your input.
About the commit msg: I would include the changed flow name(s) and a timestamp in the comment.
Also i'm wondering, how easy it is to go back to a previous version? And if there is only one flow changed, will only this flow redeployed or all from the project?
