Is there anything that technically prevents someone from using a custom JS library like this one while building a custom Node's edit interface?
No, nothing preventing you using jQuery plugins like the query builder one.
You would need to either use a CDN (would require the user to have internet access to configure your nodes settings) OR add the lib as a resource to your node (i.e. present it to the node editor via an admin endpoint)
Thanks! I will try the 2nd route to make it self-sufficient without the internet.
P.S. I hope this is the solution you were proposing: Loading extra resources in the editor : Node-RED
That is correct.
have a folder named resources in your modules root directory
reference it in your HTML file
<script type="text/javascript" src="resources/<your-module-name>/magic.js"></script>
I have many files in my resources folder, they can also have sub folders
<script type="text/javascript" src="resources/<your-module-name>/more/magic.js"></script>
