Extract a value of an array
I want to extract the value of a specific position in an array that I am receiving from Inject sent from a Raspberry Pi with the protocol OPC - UA as 'int' variable but I do not know how to do it in Node - RED
Node-RED message payload
12/04/2019, 16:47:43node: Pressure BMP180 Sensor
ns=2;i=4 : msg.payload : array[2]
array[2]
0: 0
1: 97448
12/04/2019, 16:12:22[node: Pressure BMP180 Sensor](http://10.6.4.101:1880/#)msg : string[15]
"Bad data inject"
The value i want is the 97454
My configuration in the Inject is:
I need the value of the 1: position in the array
The docs have a page called "Working with messages"
https://nodered.org/docs/user-guide/messages
That has instructions on how to get at specific data you can display with a debug node.
Using that page and either a change node or a function node you should be able to do what you want to do.
The solution for my problem i think that way is correct, it's works for my situation and i share everyone
in the msg.payload.topic[1] the 1 is the position in array i want
if anyone has a suggestion to improve the programming I am open to suggestions
Hello, I have the same problem, could you send me the configuration of each node please? My email is antarita95@gmail.com please please help me
Welcome to the forum. It is not clear exactly what problem you have. Please explain in more detail. Have you read the document linked earlier? Also if you are a newcomer to node-red I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
