Hi, Id like to extract an integer from a msg.payload.response
I just need the power data. tried many functions, but don't get it.
can someone help me out here?
this is the payload result:
"power": 3.037565,
"relay": true
best regards
Jens
"power": 3.037565,
"relay": true
best regards
Jens
Is the response from http - whats the format ? UTF or JSON object ? Did you try to converting it to JSON object. Then should be straight forward.
I think its a http response. I'm totally new in node-red and java js. dont know how to convert it to a JSON object.
when using this command in bash, i get the power data:
curl http://192.168.0.86/report | sed -n 2p | awk 'NF>1{print $NF}' | sed 's/.$//'
this is the complete msg.payload i get, when using the mystrom plugin.
Ok. It may/may not be http.
You need to send it to JSON node to convert it to JSON object.
In json node - configure - the value as msg.payload.response and setting as Convert to JSON Object.
Should work.
First use a change node and set the payload to payload.response. With this feed the json node and the get the value by extracting the power.
"id": "3c52b18925bace22",
"type": "change",
"z": "ebe8134f6b5af26c",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.response",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 450,
"y": 1360,
"b87e294ee7801cb8"
"id": "b87e294ee7801cb8",
"type": "json",
"property": "payload",
"action": "",
"pretty": false,
"x": 650,
"y": 1360,
"89193357b0838718"
"id": "89193357b0838718",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.power",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 850,
"y": 1360,
"759c0e7163544516"
"id": "759c0e7163544516",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1080,
"y": 1360,
"id": "ef1f93c641c49c47",
"type": "inject",
"props": [
"p": "payload.response",
"v": "{\"power\":2123}",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 250,
"y": 1360,
"3c52b18925bace22"
