Hi everybodies,
I am new in this field and tried to connect MQTT broker to the TTN network and extract the message.
In the next step I want to put this data into an influx db and visualize data in grafana.
The device measures gas, temperature, pressure and humidity.
How can I extract (temp, pressure, humidity and gas) from the payload?
Here is my payload msg:
{"end_device_ids":{"device_id":"eui-70b3d57ed004ae72","application_ids":{"application_id":"gps-tracker-giulio"},"dev_eui":"70B3D57ED004AE72","join_eui":"0000000000000000","dev_addr":"260BF022"},"correlation_ids":["as:up:01FV73VRZ62V82E6AG2D2T7NQR","gs:conn:01FV73GYZPBBSBPC5QWXMBKZN6","gs:up:host:01FV73GYZWTSWV21PFX8BJSNMW","gs:uplink:01FV73VRRH41SBMTJGR42YM2FM","ns:uplink:01FV73VRRNZM7BMBQ6M7C9Z0WJ","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FV73VRRNHXFDR0RJNZK82WPV","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FV73VRZ525XQ3CJDSP82WJBT"],"received_at":"2022-02-06T08:54:29.607148170Z","uplink_message":{"session_key_id":"AX7OPJCA3IZ8Mzsvs/8AKA==","f_port":2,"f_cnt":3,"frm_payload":"AQkEFBAAAY23AAAbuA==","decoded_payload":{" **GAS** ":7096," **HUM** ":51.36," **PRES** ":1018.15," **TEMP** ":23.08},"rx_metadata":[{"gateway_ids":{"gateway_id":"rak7243c","eui":"B827EBFFFE4C1D1A"},"timestamp":356658652,"rssi":-47,"channel_rssi":-47,"snr":13,"location":{"latitude":45.558211494500696,"longitude":11.56566059586112,"source":"...
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
Ps.
As a new user, here is some canned text to get you up to speed...
posting code
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil icon.
recommended watching
I recommend watching this playlist: Node-RED Essentials . The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Colin
6 February 2022 09:36
4
Make sure that in the the mqtt node you have the output set to parsed JSON. Then the node will parse the JSON string and output a JavaScript object.
Thank you very much!
I set parsed JSON and now I have this message:
How can i "extract" the data?
Thank you for the information!
↑ exactly like i described ↓
Steve-Mcl:
If you are unsure what to do once you have copied the path then you likely need to run through the recommended videos to understand the basics of node-red.
Use a change node and set the payload to the copied path from the debug window.
I.e.
Set
msg.payload
To
msg.payload.decoded_payload.TEMP
Colin
7 February 2022 09:54
9
Or if, as I do, you find it more intuitive, use
Move
To
msg.payload
