I am new to node-red and also to javascript.
I intend to extract a dynamic key/values from the data_label object and put it in msg.payload just like the picture attached.
How can I achieve this with the function node?
Regards
is this specific to data_label? If so, you can utilise a change node with JSONata:
$sift($merge([$$.payload, $$.payload.data_label]), function($val, $key) {$key != "data_label"})
https://try.jsonata.org/IOXYLdsO
What this does is that it will merge msg.payload object with the inner msg.payload.data_label object, which will give you a combined object of
"@timestamp": "2020-02-24T...",
"data_label": {
"DATA0": 6573,
"DATA1": 65
"DATA0": 6573,
"DATA1": 65
Then, it will call a $sift function on it to filter out the key in the object called data_label to get the item out. Anyone having a more simplistic solution, feel free to show how to do it better, I love improved queries
Also have a look at the node red docs on Working With Messages, that will give you further help.
Exactly what I needed!
Thank you my friend.
Regards
