Hello everyone.
Assuming I have the following SQL table (ignore the fact that the picture is from excel)-
And I receive the value 'Jerry' in the payload, how can I extract his phone number from the MS-SQL table?
Much thanks,
Hello everyone.
Much thanks,
Something like SQL Server SELECT - Querying Data from a Single Table ?
Sort of, couldn't quite yet form the picture of how it should look like in a flow.
If I am constantly receiving people's names in payloads and I want to use that payload value in order to extract their phone numbers.
What a lot of people do is use a template node to create the query string eg like "SELECT foo FROM mytable WHERE name='{{payload}}';" then pass that to the node.
Thanks! ![]()
This is amazing, thanks.
However, I receive the output as an object inside an array. How can I receive it only as an object?
It looks as so-
I cant seem to be able to call this object out with msg.payload.token.
No, because as the debug output states, msg.payload is an array.
The result of a SQL query is ALWAYS an array - because it has to represent a set of database rows - where each array element is a database row.
If you want to access the 1st row, then you would access msg.payload[0].token
CANNED TEXT...
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
Much thanks. I'll make sure to view the attached documentation you've mentioned.
