Pass msq payload to SQL query where clause
Hi node-red forum,
Is it possible to pass a msg payload to SQL query node to use in the where cluase?
I mean somenthing like this:
Which is the correct syntax?
The path of the msg payload to pass is payload.topic1[0].ID
The "better" way is to use "Parameters"
Thanks Steve.
Also if I'm using a Select query (not Insert into)?
I want to make a merge between two table and extract only raw where the ID is the one passed by a previous function output.
Parameters work with all types of queries (SELECT/UPDATE/INSERT/DELETE!
I dont think i fully understand what you are asking
Can you explain with a bit more detail please?
Do you mean to use 'parameters' like in this way?
Sure, however you need to.
e.g.
↓ When the value XXX comes from msg.payload[0].ID ↓
then...
  • SELECT * FROM T1 where id=XXX becomes
  • SELECT * FROM T1 where id=@ID
  • and add a parameter for msg.payload[0].ID named ID
