with node-red 1.2.1 installation of face recognition getting error.
What hardware and OS are you running on?
Open a terminal and (important) go to your .node-red folder. Then run
npm install node-red-contrib-face-recognition
and copy/paste the result here. When pasting it in use the </> button at the top of the forum text entry window.
Use Windows 10 with Node-red v1.21
upload the text filenpm run cmd.txt (57.6 KB) , the characters are more than limitation.
Note that that says it installed ok (after a lot rude messages)
+ node-red-contrib-face-recognition@1.3.3
added 15 packages from 18 contributors and audited 998 packages in 47.331s
If you restart node red, refresh the browser and look in the palette is it still saying there is a problem?
still getting this error.
when trying to add this flow "https://flows.nodered.org/node/node-red-contrib-face-recognition"
it show this error.
In the readme is says that tensorflow is optional.
I think you will have to raise an issue on the node's github page. However I note there is already a possibly related issue that was raised three months ago and there seems to be no action. https://github.com/thebigpotatoe/node-red-contrib-face-recognition/issues/13
