Hello
We are failling to install the node node-red-contrib-face-recognition in a Fargate container running nodered/node-red:3.0.2-16.
It fails even in a clean, created-from scratch, container so no existing dependencies from other nodes.
The error log is as follow.
Could someone help us to uderstand what it means ?
Many thanks
2023-01-02T16:09:22.139Z Install : node-red-contrib-face-recognition 2.0.4
2023-01-02T16:09:22.154Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-face-recognition@2.0.4
2023-01-02T16:09:22.760Z [err] npm
2023-01-02T16:09:22.761Z [err] WARN config production Use `--omit=dev` instead.
2023-01-02T16:09:45.679Z [err] npm WARN deprecated formidable@1.2.6: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau
2023-01-02T16:09:47.349Z [err] npm
2023-01-02T16:09:47.350Z [err] WARN deprecated node-pre-gyp@0.13.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
2023-01-02T16:10:32.061Z [err] npm ERR! code 1
2023-01-02T16:10:32.061Z [err] npm ERR! path /data/node_modules/canvas
2023-01-02T16:10:32.064Z [err] npm ERR!
2023-01-02T16:10:32.065Z [err] command failed
2023-01-02T16:10:32.065Z [err] npm ERR! command sh -c node-pre-gyp install --fallback-to-build --update-binary
2023-01-02T16:10:32.065Z [err] npm ERR! Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --update-binary --module=/data/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/data/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v93' (1)
2023-01-02T16:10:32.070Z [err] npm ERR! node-pre-gyp info it worked if it ends with ok
2023-01-02T16:10:32.070Z [err] npm ERR! node-pre-gyp info using node-pre-gyp@1.0.10
2023-01-02T16:10:32.070Z [err] npm ERR! node-pre-gyp info using node@16.16.0 | linux | x64
2023-01-02T16:10:32.070Z [err] npm ERR! node-pre-gyp http GET https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-musl-x64.tar.gz
2023-01-02T16:10:32.070Z [err] ERR! node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-musl-x64.tar.gz
2023-01-02T16:10:32.070Z [err] ERR! node-pre-gyp WARN Pre-built binaries not installable for canvas@2.11.0 and node@16.16.0 (node-v93 ABI, musl) (falling back to source compile with node-gyp)
2023-01-02T16:10:32.070Z [err] npm ERR! node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.11.0/canvas-v2.11.0-node-v93-linux-musl-x64.tar.gz
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info it worked if it ends with ok
2023-01-02T16:10:32.070Z [err] gyp info using node-gyp@9.0.0
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info using node@16.16.0 | linux | x64
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info ok
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info using node-gyp@9.0.0
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info find Python using Python version 3.10.5 found at "/usr/bin/python3"
2023-01-02T16:10:32.070Z [err] ERR! gyp http GET https://unofficial-builds.nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
2023-01-02T16:10:32.070Z [err] npm ERR! gyp http 200 https://unofficial-builds.nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
2023-01-02T16:10:32.070Z [err] npm ERR! gyp http GET https://unofficial-builds.nodejs.org/download/release/v16.16.0/SHASUMS256.txt
2023-01-02T16:10:32.070Z [err] ERR! gyp http 200 https://unofficial-builds.nodejs.org/download/release/v16.16.0/SHASUMS256.txt
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info spawn /usr/bin/python3
2023-01-02T16:10:32.070Z [err] gyp info spawn args [
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info spawn args 'binding.gyp',
2023-01-02T16:10:32.070Z [err] npm ERR! gyp info spawn args '-f',
2023-01-02T16:10:32.071Z [err] ERR! gyp info spawn args 'make',
2023-01-02T16:10:32.071Z [err] npm ERR! gyp info spawn args '-I',
2023-01-02T16:10:32.071Z [err] ERR! gyp info spawn args '/data/node_modules/canvas/build/config.gypi',
2023-01-02T16:10:32.071Z [err] gyp info spawn args '-I',
2023-01-02T16:10:32.071Z [err] npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
2023-01-02T16:10:32.071Z [err] npm ERR! gyp info spawn args '/usr/src/node-red/.cache/node-gyp/16.16.0/include/node/common.gypi',
2023-01-02T16:10:32.071Z [err] npm ERR! gyp info spawn args '-Dlibrary=shared_library',
2023-01-02T16:10:32.071Z [err] npm ERR! gyp info spawn args '-Dvisibility=default',
2023-01-02T16:10:32.071Z [err] npm ERR! gyp info spawn args '-Dnode_root_dir=/usr/src/node-red/.cache/node-gyp/16.16.0',
2023-01-02T16:10:32.071Z [err] npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
2023-01-02T16:10:32.072Z [err] ERR! gyp info spawn args '-Dnode_lib_file=/usr/src/node-red/.cache/node-gyp/16.16.0/<(target_arch)/node.lib',
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args '-Dmodule_root_dir=/data/node_modules/canvas',
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args '-Dnode_engine=v8',
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args '--depth=.',
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args '--no-parallel',
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args '--generator-output',
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args 'build',
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args '-Goutput_dir=.'
2023-01-02T16:10:32.072Z [err] npm ERR! gyp info spawn args ]
2023-01-02T16:10:32.072Z [err] npm ERR! /bin/sh: pkg-config: not found
2023-01-02T16:10:32.072Z [err] npm ERR! gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 127 while in binding.gyp. while trying to load binding.gyp
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! configure error
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:261:16)
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:527:28)
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! System Linux 5.10.102.1-microsoft-standard-WSL2
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--update-binary" "--module=/data/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/data/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v93"
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! cwd /data/node_modules/canvas
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! node -v v16.16.0
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! node-gyp -v v9.0.0
2023-01-02T16:10:32.072Z [err] npm ERR! gyp ERR! not ok
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! build error
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --update-binary --module=/data/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/data/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v93' (1)
2023-01-02T16:10:32.072Z [err] ERR! node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/data/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess.emit (node:events:527:28)
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1092:16)
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
2023-01-02T16:10:32.072Z [err] ERR! node-pre-gyp ERR! System Linux 5.10.102.1-microsoft-standard-WSL2
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! command "/usr/local/bin/node" "/data/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! cwd /data/node_modules/canvas
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! node -v v16.16.0
2023-01-02T16:10:32.072Z [err] node-pre-gyp ERR! node-pre-gyp -v v1.0.10
2023-01-02T16:10:32.072Z [err] npm ERR! node-pre-gyp ERR! not ok
2023-01-02T16:10:32.077Z [err]
2023-01-02T16:10:32.078Z [err] npm ERR! A complete log of this run can be found in:
2023-01-02T16:10:32.078Z [err] npm ERR! /data/.npm/_logs/2023-01-02T16_09_22_699Z-debug-0.log
2023-01-02T16:10:32.089Z rc=1
