Yes, exactly.
That isn't what I asked you to do, read my post again.
curl 7.68.0 (x86_64-pc-linux-gnu) libcurl/7.68.0 OpenSSL/1.1.1f zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.2.0) libssh/0.9.3/openssl/zlib nghttp2/1.40.0 librtmp/2.3
Release-Date: 2020-01-08
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
Features: AsynchDNS brotli GSS-API HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile libz NTLM NTLM_WB PSL SPNEGO SSL TLS-SRP UnixSockets
Is that the response to the command I suggested you try, in post #14? Namely
curl https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered
That will show whether curl is able to fetch the file. The fact that the bash <(curl ... command did nothing at all suggests that the curl command fetching the script failed.
#!/bin/bash
# Copyright 2016,2020 JS Foundation and other contributors, https://js.foundation/
# Copyright 2015,2016 IBM Corp.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# Node-RED Installer for DEB based systems
umask 0022
tgta=12.22.1 # need armv6l latest from https://unofficial-builds.nodejs.org/download/release/
tgtl=12.16.3 # need x86 latest from https://unofficial-builds.nodejs.org/download/release/
usage() {
cat << EOL
Usage: $0 [options]
Options:
--help display this help and exits
--confirm-root install as root without asking confirmation
--confirm-install confirm installation without asking confirmation
--confirm-pi confirm installation of PI specific nodes without asking confirmation
--nodered-version if not set, the latest version is used - e.g. --nodered-version="1.1.3"
EOL
if [ $# -gt 0 ]; then
# Parsing parameters
while (( "$#" )); do
case "$1" in
--help)
usage && exit 0
shift
--confirm-root)
CONFIRM_ROOT="y"
shift
--confirm-install)
CONFIRM_INSTALL="y"
shift
--skip-pi)
CONFIRM_PI="n"
shift
--confirm-pi)
CONFIRM_PI="y"
shift
--nodered-version=*)
NODERED_VERSION="${1#*=}"
shift
--) # end argument parsing
shift
break
-*|--*=) # unsupported flags
echo "Error: Unsupported flag $1" >&2
exit 1
esac
done
fi
echo -ne "\033[2 q"
if [[ -e /mnt/dietpi_userdata ]]; then
echo -ne "\n\033[1;32mDiet-Pi\033[0m detected - only going to add the \033[0;36mnode-red-start, -stop, -log\033[0m commands.\n"
echo -ne "Flow files and other things worth backing up can be found in the \033[0;36m/mnt/dietpi_userdata/node-red\033[0m directory.\n\n"
echo -ne "Use the \033[0;36mdietpi-software\033[0m command to un-install and re-install \033[38;5;88mNode-RED\033[0m.\n"
echo "journalctl -f -n 25 -u node-red -o cat" > /usr/bin/node-red-log
chmod +x /usr/bin/node-red-log
echo "dietpi-services stop node-red" > /usr/bin/node-red-stop
chmod +x /usr/bin/node-red-stop
echo "dietpi-services start node-red" > /usr/bin/node-red-start
echo "journalctl -f -n 0 -u node-red -o cat" >> /usr/bin/node-red-start
chmod +x /usr/bin/node-red-start
else
if [ "$EUID" == "0" ]; then
# if [[ $SUDO_USER != "" ]]; then
echo -en "\nroot user detected. Typical installs should be done as a regular user.\r\n"
echo -en "If you are running this script using sudo, please cancel and rerun without sudo.\r\n"
echo -en "If you know what you are doing as root, please continue.\r\n\r\n"
yn="${CONFIRM_ROOT}"
[ ! "${yn}" ] && read -t 10 -p "Are you really sure you want to install as root ? (y/N) ? " yn
case $yn in
[Yy]* )
echo " "
exit 1
esac
id -u nobody &>/dev/null || adduser --no-create-home --shell /dev/null --disabled-password --disabled-login --gecos '' nobody &>/dev/null
fi
if [[ "$(uname)" != "Darwin" ]]; then
# if curl -f https://www.npmjs.com/package/node-red >/dev/null 2>&1; then
if curl -I https://registry.npmjs.org/@node-red/util >/dev/null 2>&1; then
echo -e '\033]2;'Node-RED update'\007'
echo " "
echo "This script will remove versions of Node.js prior to version 12.x, and Node-RED and"
echo "if necessary replace them with Node.js 12.x LTS (erbium) and the latest Node-RED from Npm."
echo " "
echo "It also moves any Node-RED nodes that are globally installed into your user"
echo "~/.node-red/node_modules directory, and adds them to your package.json, so that"
echo "you can manage them with the palette manager."
echo " "
echo "It also tries to run 'npm rebuild' to refresh any extra nodes you have installed"
echo "that may have a native binary component. While this normally works ok, you need"
echo "to check that it succeeds for your combination of installed nodes."
echo " "
echo "To do all this it runs commands as root - please satisfy yourself that this will"
echo "not damage your Pi, or otherwise compromise your configuration."
echo "If in doubt please backup your SD card first."
echo " "
if [[ -e $HOME/.nvm ]]; then
echo -ne '\033[1mNOTE:\033[0m We notice you are using \033[38;5;88mnvm\033[0m. Please ensure it is running the current LTS version.\n'
echo -ne 'Using nvm is NOT RECOMMENDED. Node-RED will not run as a service under nvm.\r\n\n'
fi
yn="${CONFIRM_INSTALL}"
[ ! "${yn}" ] && read -p "Are you really sure you want to do this ? [y/N] ? " yn
case $yn in
[Yy]* )
echo ""
EXTRANODES=""
EXTRAW="update"
response="${CONFIRM_PI}"
[ ! "${response}" ] && read -r -t 15 -p "Would you like to install the Pi-specific nodes ? [y/N] ? " response
if [[ "$response" =~ ^([yY])+$ ]]; then
EXTRANODES="node-red-node-pi-gpio@latest node-red-node-random@latest node-red-node-ping@latest node-red-contrib-play-audio@latest node-red-node-smooth@latest node-red-node-serialport@latest"
EXTRAW="install"
fi
# this script assumes that $HOME is the folder of the user that runs node-red
# that $USER is the user name and the group name to use when running is the
# primary group of that user
# if this is not correct then edit the lines below
MYOS=$(cat /etc/*release | grep "^ID=" | cut -d = -f 2)
NODERED_HOME=$HOME
NODERED_USER=$USER
NODERED_GROUP=`id -gn`
GLOBAL="true"
TICK='\033[1;32m\u2714\033[0m'
CROSS='\033[1;31m\u2718\033[0m'
cd "$NODERED_HOME" || exit 1
clear
echo -e "\nRunning Node-RED $EXTRAW for user $USER at $HOME on $MYOS\n"
time1=$(date)
echo "" | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo "***************************************" | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo "Started : "$time1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo "Running for user $USER at $HOME" | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne '\r\nThis can take 20-30 minutes on the slower Pi versions - please wait.\r\n\n'
echo -ne ' Stop Node-RED \r\n'
echo -ne ' Remove old version of Node-RED \r\n'
echo -ne ' Remove old version of Node.js \r\n'
echo -ne ' Install Node.js \r\n'
echo -ne ' Clean npm cache \r\n'
echo -ne ' Install Node-RED core \r\n'
echo -ne ' Move global nodes to local \r\n'
echo -ne ' Install extra Pi nodes \r\n'
echo -ne ' Npm rebuild existing nodes \r\n'
echo -ne ' Add shortcut commands \r\n'
echo -ne ' Update systemd script \r\n'
echo -ne ' \r\n'
echo -ne '\r\nAny errors will be logged to /var/log/nodered-install.log\r\n'
echo -ne '\033[14A'
# stop any running node-red service
if sudo service nodered stop 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null ; then CHAR=$TICK; else CHAR=$CROSS; fi
echo -ne " Stop Node-RED $CHAR\r\n"
# save any global nodes
GLOBALNODES=$(find /usr/local/lib/node_modules/node-red-* -maxdepth 0 -type d -printf '%f\n' 2>/dev/null)
GLOBALNODES="$GLOBALNODES $(find /usr/lib/node_modules/node-red-* -maxdepth 0 -type d -printf '%f\n' 2>/dev/null)"
echo "Found global nodes: $GLOBALNODES :" | sudo tee -a /var/log/nodered-install.log >>/dev/null
# remove any old node-red installs or files
sudo apt remove -y nodered 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
# sudo apt remove -y node-red-update 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo rm -rf /usr/local/lib/node_modules/node-red* /usr/local/lib/node_modules/npm /usr/local/bin/node-red* /usr/local/bin/node /usr/local/bin/npm 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo rm -rf /usr/lib/node_modules/node-red* /usr/bin/node-red* 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne ' Remove old version of Node-RED \033[1;32m\u2714\033[0m\r\n'
nv="v0"
nv2=""
ndeb=$(apt-cache policy nodejs | grep Installed | awk '{print $2}')
if [[ -x "$(command -v node)" ]]; then
nv=`node -v | cut -d "." -f1`
nv2=`node -v`
# nv2=`apt list nodejs 2>/dev/null | grep dfsg | cut -d ' ' -f 2 | cut -d '-' -f 1`
echo "Already have nodejs $nv2" | sudo tee -a /var/log/nodered-install.log >>/dev/null
fi
# ensure ~/.config dir is owned by the user
echo "Now install nodejs" | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo chown -Rf $NODERED_USER:$NODERED_GROUP $NODERED_HOME/.config/
# maybe remove Node.js - or upgrade if nodesoure.list exists
if [[ "$(uname -m)" =~ "i686" ]]; then
echo "Using i686" | sudo tee -a /var/log/nodered-install.log >>/dev/null
curl -sSL -o /tmp/node.tgz https://unofficial-builds.nodejs.org/download/release/v$tgtl/node-v$tgtl-linux-x86.tar.gz 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
# unpack it into the correct places
hd=$(head -c 9 /tmp/node.tgz)
if [ "$hd" == "<!DOCTYPE" ]; then
CHAR="$CROSS File $f not downloaded";
else
if sudo tar -zxf /tmp/node.tgz --strip-components=1 -C /usr 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
fi
rm /tmp/node.tgz 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne " Install Node.js for i686 $CHAR"
elif uname -m | grep -q armv6l ; then
sudo apt remove -y nodejs nodejs-legacy npm 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo rm -rf /etc/apt/sources.d/nodesource.list /usr/lib/node_modules/npm*
echo -ne " Remove old version of Node.js $TICK\r\n"
echo -ne " Install Node.js for Armv6 \r"
# f=$(curl -sL https://nodejs.org/download/release/latest-dubnium/ | grep "armv6l.tar.gz" | cut -d '"' -f 2)
# curl -sL -o node.tgz https://nodejs.org/download/release/latest-dubnium/$f 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
curl -sSL -o /tmp/node.tgz https://unofficial-builds.nodejs.org/download/release/v$tgta/node-v$tgta-linux-armv6l.tar.gz 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
else
fi
# remove the tgz file to save space
echo -ne " Install Node.js for Armv6 $CHAR"
elif [[ -e $HOME/.nvm ]]; then
echo -ne ' Using NVM to manage Node.js + please run \033[0;36mnvm use lts\033[0m before running Node-RED\r\n'
echo -ne ' NOTE: Using nvm is NOT RECOMMENDED. Node-RED will not run as a service under nvm.\r\n'
export NVM_DIR=$HOME/.nvm
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh" # This loads nvm
echo "Using NVM !!! $(nvm current)" 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
nvm install --lts --no-progress --latest-npm >/dev/null 2>&1
nvm use lts >/dev/null 2>&1
nvm alias default lts >/dev/null 2>&1
echo "Now using --- $(nvm current)" 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
GLOBAL="false"
ln -f -s $HOME/.nvm/versions/node/$(nvm current)/lib/node_modules/node-red/red.js $NODERED_HOME/node-red
echo -ne " Update Node.js LTS $CHAR"
elif [[ $(which n) ]]; then
echo "Using n" | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne " Using N to manage Node.js +\r\n"
if sudo n lts 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
elif [ "$nv" = "v0" ] || [ "$nv" = "v1" ] || [ "$nv" = "v3" ] || [ "$nv" = "v4" ] || [ "$nv" = "v5" ] || [ "$nv" = "v6" ] || [ "$nv" = "v7" ] || [ "$nv" = "v8" ] || [ "$nv" = "v9" ] || [ "$nv2" = "v10.23.1" ] || [ "$nv" = "v11" ] || [ "$nv" = "v13" ] || [[ "$ndeb" =~ "dfsg" ]]; then
echo "Updating nodejs $nv2" | sudo tee -a /var/log/nodered-install.log >>/dev/null
if [[ -f /etc/apt/sources.list.d/nodesource.list ]]; then
echo "Using nodesource.list" | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo "Removing nodejs "$nv | sudo tee -a /var/log/nodered-install.log >>/dev/null
if curl -sSL https://deb.nodesource.com/setup_12.x | sudo -E bash - 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
else
CHAR="-"
fi
echo -ne " Remove old version of Node.js $CHAR $nv\r\n"
echo -ne " Update Node.js LTS \r"
if sudo apt install -y nodejs 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
else
# clean out old nodejs stuff
echo "Not using nodesource.list" | sudo tee -a /var/log/nodered-install.log >>/dev/null
npv=$(npm -v 2>/dev/null | head -n 1 | cut -d "." -f1)
sudo dpkg -r nodejs 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo dpkg -r node 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo rm -rf /opt/nodejs 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo rm -f /usr/local/bin/node* 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo rm -rf /usr/local/bin/npm* /usr/local/bin/npx* /usr/lib/node_modules/npm* 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
if [ "$npv" = "1" ]; then
sudo rm -rf /usr/local/lib/node_modules/node-red* /usr/lib/node_modules/node-red* 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
fi
sudo apt -y autoremove 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne " Remove old version of Node.js \033[1;32m\u2714\033[0m\r\n"
echo "Grab the LTS bundle" | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne " Install Node.js LTS \r"
# use the official script to install for other debian platforms
sudo apt install -y curl 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne " Install Node.js LTS $CHAR"
fi
else
CHAR="-"
echo -ne " Remove old version of Node.js $CHAR\n"
echo -ne " Leave existing Node.js $CHAR"
fi
NUPG=$CHAR
hash -r
rc=""
if nov=$(node -v 2>/dev/null); then :; else rc="ERR"; fi
if npv=$(npm -v 2>/dev/null); then :; else rc="ERR"; fi
echo "Versions: node:$nov npm:$npv" | sudo tee -a /var/log/nodered-install.log >>/dev/null
if [[ "$rc" == "" ]]; then
echo -ne " Node $nov Npm $npv\r\n"
else
echo -ne "\b$CROSS Failed to install Node.js - Exit\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n"
exit 2
fi
if [ "$EUID" == "0" ]; then npm config set unsafe-perm true &>/dev/null; fi
# clean up the npm cache and node-gyp
if [[ "$NUPG" == "$TICK" ]]; then
if [[ "$GLOBAL" == "true" ]]; then
sudo npm cache clean --force 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
else
fi
if sudo rm -rf "$NODERED_HOME/.node-gyp" "$NODERED_HOME/.npm" /root/.node-gyp /root/.npm; then CHAR=$TICK; else CHAR=$CROSS; fi
fi
echo -ne " Clean npm cache $CHAR\r\n"
# and install Node-RED
echo "Now install Node-RED" | sudo tee -a /var/log/nodered-install.log >>/dev/null
NODERED_VERSION_SELECTION=""
if [ -z ${NODERED_VERSION} ]; then
NODERED_VERSION_SELECTION="latest"
else
NODERED_VERSION_SELECTION=${NODERED_VERSION}
fi
if sudo npm i -g --unsafe-perm --no-progress --no-update-notifier --no-audit --no-fund node-red@"$NODERED_VERSION_SELECTION" 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
else
if npm i -g --unsafe-perm --no-progress --no-update-notifier --no-audit --no-fund node-red@"$NODERED_VERSION_SELECTION" 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
fi
nrv=$(npm --no-progress --no-update-notifier --no-audit --no-fund -g ls node-red | grep node-red | cut -d '@' -f 2 | sudo tee -a /var/log/nodered-install.log) >>/dev/null 2>&1
echo -ne " Install Node-RED core $CHAR $nrv\r\n"
# install any nodes, that were installed globally, as local instead
echo "Now create basic package.json for the user and move any global nodes" | sudo tee -a /var/log/nodered-install.log >>/dev/null
mkdir -p "$NODERED_HOME/.node-red/node_modules"
sudo chown -Rf $NODERED_USER:$NODERED_GROUP $NODERED_HOME/.node-red/ 2>&1 >>/dev/null
pushd "$NODERED_HOME/.node-red" 2>&1 >>/dev/null
npm config set update-notifier false 2>&1 >>/dev/null
if [ ! -f "package.json" ]; then
echo '{' > package.json
echo ' "name": "node-red-project",' >> package.json
echo ' "description": "initially created for you by Node-RED '$nrv'",' >> package.json
echo ' "version": "0.0.1",' >> package.json
echo ' "private": true,' >> package.json
echo ' "dependencies": {' >> package.json
echo ' }' >> package.json
echo '}' >> package.json
fi
CHAR="-"
if [[ $GLOBALNODES != " " ]]; then
if npm i --unsafe-perm --save --no-progress --no-update-notifier --no-audit --no-fund $GLOBALNODES 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
fi
echo -ne " Move global nodes to local $CHAR\r\n"
CHAR="-"
if [[ ! -z $EXTRANODES ]]; then
echo "Installing extra nodes: $EXTRANODES :" | sudo tee -a /var/log/nodered-install.log >>/dev/null
if npm i --unsafe-perm --save --no-progress --no-update-notifier --no-audit --no-fund $EXTRANODES 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
fi
echo -ne " Install extra Pi nodes $CHAR\r\n"
# try to rebuild any already installed nodes
if npm rebuild --unsafe-perm 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
echo -ne " Npm rebuild existing nodes $CHAR\r\n"
else
echo -ne " Npm rebuild existing nodes -\r\n"
fi
popd 2>&1 >>/dev/null
sudo chown -Rf $NODERED_USER:$NODERED_GROUP $NODERED_HOME/.npm 2>&1 >>/dev/null
# add the shortcut and start/stop/log scripts to the menu
echo "Now add the shortcut and start/stop/log scripts to the menu" | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo mkdir -p /usr/bin
if curl -f https://raw.githubusercontent.com/node-red/linux-installers/master/resources/node-red-icon.svg >/dev/null 2>&1; then
sudo curl -sL -o /usr/share/icons/hicolor/scalable/apps/node-red-icon.svg https://raw.githubusercontent.com/node-red/linux-installers/master/resources/node-red-icon.svg 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo curl -sL -o /usr/share/applications/Node-RED.desktop https://raw.githubusercontent.com/node-red/linux-installers/master/resources/Node-RED.desktop 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo curl -sL -o /usr/bin/node-red-start https://raw.githubusercontent.com/node-red/linux-installers/master/resources/node-red-start 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo curl -sL -o /usr/bin/node-red-stop https://raw.githubusercontent.com/node-red/linux-installers/master/resources/node-red-stop 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo curl -sL -o /usr/bin/node-red-restart https://raw.githubusercontent.com/node-red/linux-installers/master/resources/node-red-restart 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo curl -sL -o /usr/bin/node-red-reload https://raw.githubusercontent.com/node-red/linux-installers/master/resources/node-red-reload 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo curl -sL -o /usr/bin/node-red-log https://raw.githubusercontent.com/node-red/linux-installers/master/resources/node-red-log 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo curl -sL -o /etc/logrotate.d/nodered https://raw.githubusercontent.com/node-red/linux-installers/master/resources/nodered.rotate 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo chmod +x /usr/bin/node-red-start
sudo chmod +x /usr/bin/node-red-stop
sudo chmod +x /usr/bin/node-red-restart
sudo chmod +x /usr/bin/node-red-reload
sudo chmod +x /usr/bin/node-red-log
echo -ne " Add shortcut commands $TICK\r\n"
else
echo -ne " Add shortcut commands $CROSS\r\n"
fi
# add systemd script and configure it for $USER
echo "Now add systemd script and configure it for $USER" | sudo tee -a /var/log/nodered-install.log >>/dev/null
if sudo curl -sL -o /lib/systemd/system/nodered.service https://raw.githubusercontent.com/node-red/linux-installers/master/resources/nodered.service 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null; then CHAR=$TICK; else CHAR=$CROSS; fi
# set the memory, User Group and WorkingDirectory in nodered.service
if [ $(cat /proc/meminfo | grep MemTotal | cut -d ":" -f 2 | cut -d "k" -f 1 | xargs) -lt 894000 ]; then mem="256"; else mem="512"; fi
if [ $(cat /proc/meminfo | grep MemTotal | cut -d ":" -f 2 | cut -d "k" -f 1 | xargs) -gt 1894000 ]; then mem="1024"; fi
if [ $(cat /proc/meminfo | grep MemTotal | cut -d ":" -f 2 | cut -d "k" -f 1 | xargs) -gt 3894000 ]; then mem="2048"; fi
# if [ $(cat /proc/meminfo | grep MemTotal | cut -d ":" -f 2 | cut -d "k" -f 1 | xargs) -gt 7894000 ]; then mem="4096"; fi
sudo sed -i 's#=512#='$mem'#;' /lib/systemd/system/nodered.service
sudo sed -i 's#^User=pi#User='$NODERED_USER'#;s#^Group=pi#Group='$NODERED_GROUP'#;s#^WorkingDirectory=/home/pi#WorkingDirectory='$NODERED_HOME'#;' /lib/systemd/system/nodered.service
sudo systemctl daemon-reload 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo -ne " Update systemd script $CHAR\r\n"
sudo ln -s $(which python3) /usr/bin/python 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
# remove unneeded large sentiment library to save space and load time
sudo rm -f /usr/lib/node_modules/node-red/node_modules/multilang-sentiment/build/output/build-all.json 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
# on LXDE add launcher to top bar, refresh desktop menu
file=/home/$NODERED_USER/.config/lxpanel/LXDE-pi/panels/panel
if [ -e $file ]; then
if ! grep -q "Node-RED" $file; then
mat="lxterminal.desktop"
ins="lxterminal.desktop\n }\n Button {\n id=Node-RED.desktop"
sudo sed -i "s|$mat|$ins|" $file 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
if xhost >& /dev/null ; then
export DISPLAY=:0 && lxpanelctl restart 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
fi
fi
fi
# on Pi, add launcher to top bar, add cpu temp example, make sure ping works
echo "Now add launcher to top bar, add cpu temp example, make sure ping works" | sudo tee -a /var/log/nodered-install.log >>/dev/null
if sudo grep -q BCM2 /proc/cpuinfo; then
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`) 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo setcap cap_net_raw=ep /bin/ping 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
sudo adduser $NODERED_USER gpio 2>&1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
fi
echo -ne "\r\n\r\n\r\n"
echo -ne "All done.\r\n"
echo -ne " You can now start Node-RED with the command \033[0;36mnode-red-start\033[0m\r\n"
echo -ne " or using the icon under Menu / Programming / Node-RED\r\n"
else
echo -ne " You can now start Node-RED with the command \033[0;36m./node-red\033[0m\r\n"
fi
echo -ne " Then point your browser to \033[0;36mlocalhost:1880\033[0m or \033[0;36mhttp://{your_pi_ip-address}:1880\033[0m\r\n"
echo -ne "\r\nStarted $time1 - Finished $(date)\r\n\r\n"
echo "Memory : $(free -h -t | grep Total | awk '{print $2}' | cut -d i -f 1)" | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo "Finished : "$time1 | sudo tee -a /var/log/nodered-install.log >>/dev/null
echo " "
exit 1
esac
else
echo " "
echo "Sorry - cannot connect to internet - not going to touch anything."
echo "https://www.npmjs.com/package/node-red is not reachable."
echo "Please ensure you have a working internet connection."
echo "Return code from curl is "$?
echo " "
exit 1
fi
else
echo " "
echo "Sorry - I'm not supposed to be run on a Mac."
echo "Please see the documentation at http://nodered.org/docs/getting-started/upgrading."
echo " "
exit 1
fi
fi
[Admin edited to add three backticks around so that forum does not mess with the format]
Well that looks ok. But if you run the script
it does nothing? By which I assumed that you meant it just returned to the terminal prompt immediately.
Now the script has been able to load, and node-red-start already works, but it gives an error when starting.
18:38:07 - [info]
Welcome to Node-RED
22 May 18:38:07 - [info] Node-RED version: v1.3.5
22 May 18:38:07 - [info] Node.js version: v12.22.1
22 May 18:38:07 - [info] Linux 5.8.0-53-generic x64 LE
22 May 18:38:07 - [info] Loading palette nodes
22 May 18:38:08 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
22 May 18:38:08 - [info] Settings file : /home/santos/.node-red/settings.js
22 May 18:38:08 - [info] Context store : 'default' [module=memory]
22 May 18:38:08 - [info] User directory : /home/santos/.node-red
22 May 18:38:08 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 May 18:38:08 - [info] Flows file : /home/santos/.node-red/flows_tecnoce.json
22 May 18:38:08 - [info] Creating new flow file
your credentials.
22 May 18:38:08 - [error] Unable to listen on http://127.0.0.1:1880/
22 May 18:38:08 - [error] Error: port in use
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Scheduled restart job, restart counter is at 26.
Stopped Node-RED graphical event wiring tool.
22 May 18:38:28 - [info]
Welcome to Node-RED
22 May 18:38:28 - [info] Node-RED version: v1.3.5
22 May 18:38:28 - [info] Node.js version: v12.22.1
22 May 18:38:28 - [info] Linux 5.8.0-53-generic x64 LE
22 May 18:38:28 - [info] Loading palette nodes
22 May 18:38:29 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
22 May 18:38:29 - [info] Settings file : /home/santos/.node-red/settings.js
22 May 18:38:29 - [info] Context store : 'default' [module=memory]
22 May 18:38:29 - [info] User directory : /home/santos/.node-red
22 May 18:38:29 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 May 18:38:29 - [info] Flows file : /home/santos/.node-red/flows_tecnoce.json
22 May 18:38:29 - [info] Creating new flow file
your credentials.
22 May 18:38:29 - [error] Unable to listen on http://127.0.0.1:1880/
22 May 18:38:29 - [error] Error: port in use
nodered.service: Scheduled restart job, restart counter is at 27.
22 May 18:38:50 - [info]
Welcome to Node-RED
22 May 18:38:50 - [info] Node-RED version: v1.3.5
22 May 18:38:50 - [info] Node.js version: v12.22.1
22 May 18:38:50 - [info] Linux 5.8.0-53-generic x64 LE
22 May 18:38:50 - [info] Loading palette nodes
22 May 18:38:50 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
22 May 18:38:50 - [info] Settings file : /home/santos/.node-red/settings.js
22 May 18:38:50 - [info] Context store : 'default' [module=memory]
22 May 18:38:50 - [info] User directory : /home/santos/.node-red
22 May 18:38:50 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 May 18:38:50 - [info] Flows file : /home/santos/.node-red/flows_tecnoce.json
22 May 18:38:50 - [info] Creating new flow file
your credentials.
22 May 18:38:50 - [error] Unable to listen on http://127.0.0.1:1880/
22 May 18:38:50 - [error] Error: port in use
Hi - the error
most likely means that another instance of Node-RED is still running... either the old snap or another attempt you had to run it. You need to stop/kill whichever it is - if node-red then try node-red-stop - if the snap then try sudo snap stop node-red
Finally it worked perfectly. The problem is that to install these modbus nodes you have to do it by launching node-red from the terminal. Nod-red can be launched from ubuntu programs, but the node-red-stop commands don't work. That is why it gives the message that there is another process running.
Thank you very much to all. Remember those who work with ubuntu, you have to install the script.
I have continued to investigate the problem. It takes place when node-red is launched from ubuntu, and also from the terminal, the only way to stop it from the terminal is with sudo snap stop node-red. It would be necessary to know how it can be stopped permanently from Ubuntu.
