Ubuntu 20.04 Node Red and node-red-contrib-modbus
I would like to install the node-red-contrib-modbus under ubuntu 20.04 and node red 1.0.6.
I cant get it work. I get the following error.
2020-07-22T12:36:21.813Z installieren : node-red-contrib-modbus 5.13.3
2020-07-22T12:36:22.334Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-modbus@5.13.3
2020-07-22T12:36:27.813Z [out]
2020-07-22T12:36:27.813Z [out] > @serialport/bindings@9.0.0 install /root/snap/node-red/595/node_modules/@serialport/bindings
2020-07-22T12:36:27.813Z [out] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-07-22T12:36:27.953Z [err] prebuild-install
2020-07-22T12:36:27.953Z [err]  WARN install EPERM: operation not permitted, lchown '/root/snap/node-red/595/node_modules/@serialport/bindings/build/Release'
2020-07-22T12:36:28.309Z [err] gyp
2020-07-22T12:36:28.309Z [err]  ERR! build error
2020-07-22T12:36:28.310Z [err] stack Error: not found: make
2020-07-22T12:36:28.310Z [err] gyp ERR!
2020-07-22T12:36:28.310Z [err]  stack     at getNotFoundError (/snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:13:12)
2020-07-22T12:36:28.310Z [err]  stack     at F (/snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:68:19)
2020-07-22T12:36:28.310Z [err]  stack     at E (/snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:80:29)
2020-07-22T12:36:28.310Z [err]  stack     at /snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:89:16
2020-07-22T12:36:28.310Z [err]  stack     at /snap/node-red/595/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2020-07-22T12:36:28.310Z [err]  stack     at /snap/node-red/595/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2020-07-22T12:36:28.310Z [err]  stack     at FSReqWrap.oncomplete (fs.js:153:21)
2020-07-22T12:36:28.310Z [err]  ERR! System
2020-07-22T12:36:28.310Z [err]  Linux 5.4.0-42-generic
2020-07-22T12:36:28.310Z [err] command "/snap/node-red/595/bin/node" "/snap/node-red/595/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2020-07-22T12:36:28.310Z [err]  ERR! cwd
2020-07-22T12:36:28.310Z [err]  /root/snap/node-red/595/node_modules/@serialport/bindings
2020-07-22T12:36:28.310Z [err]  node -v
2020-07-22T12:36:28.310Z [err]  v10.20.1
2020-07-22T12:36:28.310Z [err] node-gyp -v v5.1.0
2020-07-22T12:36:28.310Z [err] ERR! not ok
2020-07-22T12:36:28.316Z [out]
2020-07-22T12:36:28.316Z [out] > @serialport/bindings@8.0.8 install /root/snap/node-red/595/node_modules/modbus-serial/node_modules/@serialport/bindings
2020-07-22T12:36:28.316Z [out] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2020-07-22T12:36:28.452Z [err] prebuild-install
2020-07-22T12:36:28.452Z [err]  WARN install EPERM: operation not permitted, lchown '/root/snap/node-red/595/node_modules/modbus-serial/node_modules/@serialport/bindings/build/Release'
2020-07-22T12:36:28.808Z [err] gyp
2020-07-22T12:36:28.808Z [err]  ERR! build error
2020-07-22T12:36:28.808Z [err] stack Error: not found: make
2020-07-22T12:36:28.808Z [err] gyp ERR!
2020-07-22T12:36:28.808Z [err]      at getNotFoundError (/snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:13:12)
2020-07-22T12:36:28.808Z [err]  stack     at F (/snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:68:19)
2020-07-22T12:36:28.809Z [err]  stack
2020-07-22T12:36:28.809Z [err]      at E (/snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:80:29)
2020-07-22T12:36:28.809Z [err] gyp
2020-07-22T12:36:28.809Z [err] ERR! stack
2020-07-22T12:36:28.809Z [err]      at /snap/node-red/595/lib/node_modules/npm/node_modules/which/which.js:89:16
2020-07-22T12:36:28.809Z [err]      at /snap/node-red/595/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2020-07-22T12:36:28.809Z [err]      at /snap/node-red/595/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2020-07-22T12:36:28.809Z [err]      at FSReqWrap.oncomplete (fs.js:153:21)
2020-07-22T12:36:28.809Z [err] System Linux 5.4.0-42-generic
2020-07-22T12:36:28.809Z [err] command "/snap/node-red/595/bin/node" "/snap/node-red/595/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2020-07-22T12:36:28.809Z [err] ERR! cwd
2020-07-22T12:36:28.809Z [err]  /root/snap/node-red/595/node_modules/modbus-serial/node_modules/@serialport/bindings
2020-07-22T12:36:28.809Z [err] gyp ERR!
2020-07-22T12:36:28.809Z [err]  node -v v10.20.1
2020-07-22T12:36:28.809Z [err] node-gyp -v v5.1.0
2020-07-22T12:36:28.809Z [err] not ok
2020-07-22T12:36:28.927Z [err] npm
2020-07-22T12:36:28.927Z [err] WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@9.0.0 (node_modules/@serialport/bindings):
2020-07-22T12:36:28.927Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@9.0.0 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
2020-07-22T12:36:28.927Z [err] npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
2020-07-22T12:36:28.929Z [err] npm
2020-07-22T12:36:28.929Z [err] ERR! code ELIFECYCLE
2020-07-22T12:36:28.929Z [err] ERR! errno 1
2020-07-22T12:36:28.930Z [err] npm
2020-07-22T12:36:28.930Z [err]  ERR! @serialport/bindings@8.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
2020-07-22T12:36:28.930Z [err]  ERR! Exit status 1
2020-07-22T12:36:28.930Z [err]  ERR! Failed at the @serialport/bindings@8.0.8 install script.
2020-07-22T12:36:28.930Z [err]  This is probably not a problem with npm. There is likely additional logging output above.
2020-07-22T12:36:28.966Z [err]
2020-07-22T12:36:28.966Z [err] npm ERR! A complete log of this run can be found in:
2020-07-22T12:36:28.966Z [err] npm ERR!     /root/snap/node-red/595/.npm/_logs/2020-07-22T12_36_28_935Z-debug.log
2020-07-22T12:36:28.976Z rc=1
it looks like you are using snap rather than the full version of Node-RED. The snap version is restricted to its container so doesn't have access to external build tools required to build the bindings and indeed the serial port plug was for a long time not dynamic - that may have changed (not sure) but would need someone with snap skills to help work it out.
You can use the pi install script to install on Ubuntu. Remove the snap first.
