Dear colleagues. I am starting node-red with ubuntu and I have the following problem. I have installed it on ubuntu, and it runs on localhost: 1880. It runs directly when Linux starts. The problem I have had when trying to load node-red-contrib-modbus. It gives me the following error
Failed to install: node-red-contrib-modbus
Install failed Check the log for more information
Later I have installed it with npm from the ubuntu terminal. I think I have done it in the correct directory, (node_modules), but it still does not appear on the palette. If it seems that it is loaded as we see in the screenshot.
021-05-21T18:15:59.517Z Install : node-red-contrib-modbus 5.14.0
2021-05-21T18:15:59.520Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-modbus@5.14.0
2021-05-21T18:16:13.060Z [out]
2021-05-21T18:16:13.060Z [out] > @serialport /bindings@9.0.7 install /root/snap/node-red/675/node_modules/@serialport /bindings
2021-05-21T18:16:13.060Z [out] > prebuild-install --tag-prefix @serialport /bindings@ || node-gyp rebuild
2021-05-21T18:16:13.295Z [err] prebuild-install
2021-05-21T18:16:13.295Z [err] WARN
2021-05-21T18:16:13.295Z [err] install
2021-05-21T18:16:13.295Z [err] EPERM: operation not permitted, lchown '/root/snap/node-red/675/node_modules/@serialport /bindings/build/Release'
2021-05-21T18:16:14.192Z [err] gyp
2021-05-21T18:16:14.192Z [err] ERR! build error
2021-05-21T18:16:14.193Z [err] gyp ERR! stack Error: not found: make
2021-05-21T18:16:14.193Z [err] at getNotFoundError (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:13:12)
2021-05-21T18:16:14.193Z [err] ERR! stack
2021-05-21T18:16:14.193Z [err] at F (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:68:19)
2021-05-21T18:16:14.193Z [err] stack at E (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:80:29)
2021-05-21T18:16:14.193Z [err] at /snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:89:16
2021-05-21T18:16:14.193Z [err] stack at /snap/node-red/675/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2021-05-21T18:16:14.193Z [err] stack at /snap/node-red/675/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2021-05-21T18:16:14.193Z [err] stack at FSReqWrap.oncomplete (fs.js:153:21)
2021-05-21T18:16:14.194Z [err] gyp
2021-05-21T18:16:14.194Z [err] ERR!
2021-05-21T18:16:14.194Z [err] System Linux 5.8.0-53-generic
2021-05-21T18:16:14.194Z [err] command
2021-05-21T18:16:14.194Z [err] "/snap/node-red/675/bin/node" "/snap/node-red/675/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2021-05-21T18:16:14.194Z [err] cwd /root/snap/node-red/675/node_modules/@serialport /bindings
2021-05-21T18:16:14.194Z [err] node -v v10.23.3
2021-05-21T18:16:14.194Z [err] ERR! node-gyp -v v5.1.0
2021-05-21T18:16:14.194Z [err] not ok
2021-05-21T18:16:14.551Z [err] npm
2021-05-21T18:16:14.551Z [err] ERR! code ELIFECYCLE
2021-05-21T18:16:14.552Z [err] ERR! errno 1
2021-05-21T18:16:14.559Z [err] npm
2021-05-21T18:16:14.560Z [err] ERR! @serialport /bindings@9.0.7 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2021-05-21T18:16:14.560Z [err] npm ERR!
2021-05-21T18:16:14.560Z [err] Exit status 1
2021-05-21T18:16:14.560Z [err] Failed at the @serialport /bindings@9.0.7 install script.
2021-05-21T18:16:14.561Z [err] ERR!
2021-05-21T18:16:14.561Z [err] This is probably not a problem with npm. There is likely additional logging output above.
2021-05-21T18:16:14.624Z [err]
2021-05-21T18:16:14.624Z [err] npm ERR! A complete log of this run can be found in:
2021-05-21T18:16:14.624Z [err] /root/snap/node-red/675/.npm/_logs/2021-05-21T18_16_14_580Z-debug.log
2021-05-21T18:16:14.655Z rc=1
Someone has a solution
Colin
21 May 2021 20:25
2
Are you using a snap install of node-red? If so is there a reason for using that rather than the recommended method for Ubuntu, Raspbian and other Debian derivatives?
That is not the correct folder, though I can't say which is the correct folder other than it should be the one where you flows and settings files are. If you start node-red in a terminal the startup log will tell you where that is. If you have used the recommended install method it will be ~/.node-red
Thanks for your reply. I used npm as described in the link.
https://nodered.org/docs/getting-started/local
Colin
21 May 2021 20:42
4
OK, you can install it yourself if you want (note that at the top of that page is the link to the Ubuntu install).
Stop node-red and start it again in a terminal please and post the log here. When pasting it in use the </> button at the top of the forum entry window.
This is what comes out when starting node-red from the terminal. It stays activated even if I close the terminal.
santos@tecnoce:~$ node-red
21 May 22:49:52 - [info]
Welcome to Node-RED
21 May 22:49:52 - [info] Node-RED version: v1.3.5
21 May 22:49:52 - [info] Node.js version: v10.19.0
21 May 22:49:52 - [info] Linux 5.8.0-53-generic x64 LE
21 May 22:49:53 - [info] Loading palette nodes
21 May 22:49:53 - [info] Settings file : /home/santos/.node-red/settings.js
21 May 22:49:53 - [info] Context store : 'default' [module=memory]
21 May 22:49:53 - [info] User directory : /home/santos/.node-red
21 May 22:49:53 - [warn] Projects disabled : editorTheme.projects.enabled=false
21 May 22:49:53 - [info] Flows file : /home/santos/.node-red/flows_tecnoce.json
21 May 22:49:53 - [info] Creating new flow file
your credentials.
21 May 22:49:53 - [error] Unable to listen on http://127.0.0.1:1880/
21 May 22:49:53 - [error] Error: port in use
Colin
21 May 2021 20:59
6
That is probably because you already have node-red running.
That tells us you need to be in that folder if you want to install a node using npm from the command line.
Yes, node-red is always running, even if I close the terminal. Before, I worked with windows and that didn't happen, I had to run node-red every time I started the computer.
Colin
21 May 2021 21:08
8
If you installed the usual scripts then you can stop and start using
node-red-stop
node-red-start
If you do install a node from the command line you need to restart node-red before it will see the new nodes.
Colin:
node-red-stop
When I type node-red-stop it tells me that it cannot find the command.
Colin
21 May 2021 21:20
10
That is because you did not use the recommended script, which would install the commands for you. You can still run that script now if you want, it should add the stuff you have not installed yourself.
Thanks, I hadn't installed the scripts. I am doing it minus this command which does not work.
I am literally typing it in the console, but I don't know if anything else is necessary.
Colin
22 May 2021 06:04
12
What happens when you run it? Have you installed curl?
Also see the prerequisites section on the page.
Good Morning. Thanks for your interest. I think I know where the problems are. I uninstalled node-red. But then I have realized that ubuntu has it integrated. With node-red uninstalled it works the same on localhost
http://localhost:1880/#flow/41328911.f504f8
That is why it gave me the error of the port has occupied. Nodes can be installed here but it does not allow modbus nodes, which is where I detected the problem initially.
I paste the error log again when trying to install node-red-contribution-modbus
36:59.728Z Install : node-red-contrib-modbus 5.14.0
2021-05-22T09:36:59.799Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-modbus@5.14.0
2021-05-22T09:37:11.636Z [out]
2021-05-22T09:37:11.636Z [out] > @serialport /bindings@9.0.7 install /root/snap/node-red/675/node_modules/@serialport /bindings
2021-05-22T09:37:11.636Z [out] > prebuild-install --tag-prefix @serialport /bindings@ || node-gyp rebuild
2021-05-22T09:37:11.929Z [err] prebuild-install
2021-05-22T09:37:11.929Z [err] WARN install EPERM: operation not permitted, lchown '/root/snap/node-red/675/node_modules/@serialport /bindings/build/Release'
2021-05-22T09:37:13.373Z [err] gyp
2021-05-22T09:37:13.373Z [err] ERR!
2021-05-22T09:37:13.373Z [err] build error
2021-05-22T09:37:13.373Z [err] gyp ERR!
2021-05-22T09:37:13.373Z [err] stack Error: not found: make
2021-05-22T09:37:13.373Z [err] ERR! stack
2021-05-22T09:37:13.373Z [err] at getNotFoundError (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:13:12)
2021-05-22T09:37:13.373Z [err] ERR! stack at F (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:68:19)
2021-05-22T09:37:13.373Z [err] gyp ERR! stack
2021-05-22T09:37:13.373Z [err] at E (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:80:29)
2021-05-22T09:37:13.374Z [err] ERR! stack
2021-05-22T09:37:13.374Z [err] at /snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:89:16
2021-05-22T09:37:13.374Z [err] gyp
2021-05-22T09:37:13.374Z [err] at /snap/node-red/675/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2021-05-22T09:37:13.374Z [err] stack at /snap/node-red/675/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2021-05-22T09:37:13.374Z [err] at FSReqWrap.oncomplete (fs.js:153:21)
2021-05-22T09:37:13.374Z [err] ERR! System Linux 5.8.0-53-generic
2021-05-22T09:37:13.374Z [err] ERR! command
2021-05-22T09:37:13.374Z [err] "/snap/node-red/675/bin/node" "/snap/node-red/675/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2021-05-22T09:37:13.374Z [err] gyp ERR!
2021-05-22T09:37:13.374Z [err] cwd /root/snap/node-red/675/node_modules/@serialport /bindings
2021-05-22T09:37:13.374Z [err] ERR! node -v
2021-05-22T09:37:13.374Z [err] v10.23.3
2021-05-22T09:37:13.374Z [err] ERR! node-gyp -v
2021-05-22T09:37:13.374Z [err] v5.1.0
2021-05-22T09:37:13.375Z [err] not ok
2021-05-22T09:37:13.701Z [err] npm
2021-05-22T09:37:13.701Z [err] ERR! code ELIFECYCLE
2021-05-22T09:37:13.703Z [err] npm
2021-05-22T09:37:13.703Z [err] ERR!
2021-05-22T09:37:13.703Z [err] errno 1
2021-05-22T09:37:13.712Z [err] npm ERR!
2021-05-22T09:37:13.712Z [err] @serialport /bindings@9.0.7 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2021-05-22T09:37:13.712Z [err] npm ERR! Exit status 1
2021-05-22T09:37:13.712Z [err] Failed at the @serialport /bindings@9.0.7 install script.
2021-05-22T09:37:13.712Z [err] This is probably not a problem with npm. There is likely additional logging output above.
2021-05-22T09:37:13.782Z [err]
2021-05-22T09:37:13.783Z [err] npm ERR! A complete log of this run can be found in:
2021-05-22T09:37:13.783Z [err] /root/snap/node-red/675/.npm/_logs/2021-05-22T09_37_13_723Z-debug.log
2021-05-22T09:37:13.797Z rc=1
2021-05-22T09:52:14.345Z Install : node-red-contrib-modbus 5.14.0
2021-05-22T09:52:14.361Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-modbus@5.14.0
2021-05-22T09:52:18.644Z [out]
2021-05-22T09:52:18.644Z [out] > @serialport /bindings@9.0.7 install /root/snap/node-red/675/node_modules/@serialport /bindings
2021-05-22T09:52:18.644Z [out] > prebuild-install --tag-prefix @serialport /bindings@ || node-gyp rebuild
2021-05-22T09:52:18.867Z [err] prebuild-install
2021-05-22T09:52:18.867Z [err] WARN
2021-05-22T09:52:18.867Z [err] install EPERM: operation not permitted, lchown '/root/snap/node-red/675/node_modules/@serialport /bindings/build/Release'
2021-05-22T09:52:19.688Z [err] gyp
2021-05-22T09:52:19.688Z [err] ERR! build error
2021-05-22T09:52:19.689Z [err] gyp
2021-05-22T09:52:19.689Z [err] ERR! stack Error: not found: make
2021-05-22T09:52:19.689Z [err] gyp ERR!
2021-05-22T09:52:19.689Z [err] stack at getNotFoundError (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:13:12)
2021-05-22T09:52:19.689Z [err] stack at F (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:68:19)
2021-05-22T09:52:19.689Z [err] at E (/snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:80:29)
2021-05-22T09:52:19.689Z [err] at /snap/node-red/675/lib/node_modules/npm/node_modules/which/which.js:89:16
2021-05-22T09:52:19.690Z [err] ERR! stack
2021-05-22T09:52:19.690Z [err] at /snap/node-red/675/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2021-05-22T09:52:19.690Z [err] gyp
2021-05-22T09:52:19.690Z [err] at /snap/node-red/675/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2021-05-22T09:52:19.690Z [err] at FSReqWrap.oncomplete (fs.js:153:21)
2021-05-22T09:52:19.690Z [err] ERR! System
2021-05-22T09:52:19.690Z [err] Linux 5.8.0-53-generic
2021-05-22T09:52:19.690Z [err] command
2021-05-22T09:52:19.690Z [err] "/snap/node-red/675/bin/node" "/snap/node-red/675/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2021-05-22T09:52:19.690Z [err] cwd
2021-05-22T09:52:19.691Z [err] /root/snap/node-red/675/node_modules/@serialport /bindings
2021-05-22T09:52:19.691Z [err] gyp
2021-05-22T09:52:19.691Z [err] ERR!
2021-05-22T09:52:19.691Z [err] node -v
2021-05-22T09:52:19.691Z [err] v10.23.3
2021-05-22T09:52:19.691Z [err] node-gyp -v v5.1.0
2021-05-22T09:52:19.691Z [err] not ok
2021-05-22T09:52:19.947Z [err] npm
2021-05-22T09:52:19.947Z [err] ERR! code ELIFECYCLE
2021-05-22T09:52:19.947Z [err] npm ERR!
2021-05-22T09:52:19.947Z [err] errno 1
2021-05-22T09:52:19.949Z [err] npm
2021-05-22T09:52:19.949Z [err] ERR! @serialport /bindings@9.0.7 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2021-05-22T09:52:19.950Z [err] ERR! Exit status 1
2021-05-22T09:52:19.950Z [err] npm ERR!
2021-05-22T09:52:19.950Z [err] Failed at the @serialport /bindings@9.0.7 install script.
2021-05-22T09:52:19.950Z [err] ERR! This is probably not a problem with npm. There is likely additional logging output above.
2021-05-22T09:52:19.999Z [err]
2021-05-22T09:52:19.999Z [err] npm ERR! A complete log of this run can be found in:
2021-05-22T09:52:19.999Z [err] /root/snap/node-red/675/.npm/_logs/2021-05-22T09_52_19_957Z-debug.log
2021-05-22T09:52:20.010Z rc=1
Colin
22 May 2021 09:54
14
Running the script would have uninstalled the original node-red. Have you managed to run it yet? If not then do these commands work?
ping raw.githubusercontent.com
curl https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered
The latter should download and show the script contents.
Running ping gives the following
@tecnoce :~/node_modules$ ping raw.githubusercontent.com
PING raw.githubusercontent.com (185.199.111.133) 56(84) bytes of data.
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=1 ttl=57 time=15.8 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=2 ttl=57 time=17.2 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=3 ttl=57 time=38.6 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=4 ttl=57 time=17.8 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=5 ttl=57 time=16.6 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=6 ttl=57 time=17.6 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=7 ttl=57 time=30.7 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=8 ttl=57 time=38.2 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=9 ttl=57 time=16.7 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=10 ttl=57 time=16.5 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=11 ttl=57 time=16.3 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=12 ttl=57 time=16.9 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=13 ttl=57 time=47.6 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=14 ttl=57 time=16.7 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=15 ttl=57 time=18.0 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=16 ttl=57 time=83.6 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=17 ttl=57 time=25.3 ms
64 bytes from cdn-185-199-111-133.github.com (185.199.111.133): icmp_seq=18 ttl=57 time=44.8 ms
Colin
22 May 2021 10:27
16
OK, that shows you can access the server. Does the curl command work?
I've used the curl command like this but it doesn't work.
bash <(curl -sl://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)
When you uninstalled. You did uninstall the snap version didn’t you ? From the log above it looks like it’s still the running one
dceejay:
snap
I'm checking. I uninstalled sap and have also uninstalled nodejs. However node-red still works on localhost. I get the impression that it is another version built into the ubuntu system.
So you did
sudo snap remove node-red
