Welcome to the forum @CESLBM
That file is messed up. It holds the persistent context values for one of your flows. If the saved context values are not important then you can delete that file and it will be recreated when you use flow.context again. If the values are important then post the contents of that file in case it can be recovered.
Hi Colin,
thanks for you reply. If I understand it right, I should delete the flow.json. After I did it, it comes another error:
9 Jan 10:39:38 - [info] Node-RED version: v3.0.2
9 Jan 10:39:38 - [info] Node.js version: v16.16.0
9 Jan 10:39:38 - [info] Windows_NT 10.0.14393 x64 LE
9 Jan 10:39:43 - [info] Loading palette nodes
9 Jan 10:39:53 - [info] Settings file : C:\Users\InfoLabor.node-red\settings.js
9 Jan 10:39:53 - [info] Context store : 'default' [module=localfilesystem]
9 Jan 10:39:53 - [error] Failed to start server:
9 Jan 10:39:53 - [error] Error: Error loading context store: Error: Invalid JSON in context file '\Users\InfoLabor.node-red\context\global\global.json'
at C:\Users\InfoLabor\AppData\Roaming\nvm\v16.16.0\node_modules\node-red\node_modules@node-red\runtime\lib\nodes\context\index.js:180:15
And when I delete this global.json, came error after the node-red is started:
9 Jan 10:42:31 - [info] Starting flows
9 Jan 10:42:36 - [info] Started flows
09:42:41.753Z :client_session_impl :1507 [NODE-OPCUA-W21] Pending transactions: CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest CreateMonitoredItemsRequest
09:42:41.763Z :client_session_impl :1512 [NODE-OPCUA-W22] Warning : your opcua client is sending multiple requests simultaneously to the server CreateMonitoredItemsRequest
... please fix your application code
9 Jan 10:42:42 - [red] Uncaught Exception:
9 Jan 10:42:42 - [error] Error: subscription must be active and not terminated
at assert (C:\Users\InfoLabor.node-red\node_modules\node-opcua-assert\source\index.ts:12:21)
at ClientSubscriptionImpl._add_monitored_item (C:\Users\InfoLabor.node-red\node_modules\node-opcua-client\source\private\client_subscription_impl.ts:660:15)
at ClientMonitoredItemImpl._before_create (C:\Users\InfoLabor.node-red\node_modules\node-opcua-client\source\private\client_monitored_item_impl.ts:334:22)
at Function._toolbox_monitor (C:\Users\InfoLabor.node-red\node_modules\node-opcua-client\source\client_monitored_item_toolbox.ts:61:27)
at C:\Users\InfoLabor.node-red\node_modules\node-opcua-client\source\private\client_subscription_impl.ts:1004:40
at Immediate.waitForSubscriptionAndMonitor (C:\Users\InfoLabor.node-red\node_modules\node-opcua-client\source\private\client_subscription_impl.ts:693:17)
at processImmediate (node:internal/timers:466:21)
Did I understand your response correctly? Could you pls give me some further advice? Thanks a lot
