Failing at installing node-red-contrib-bme280
im failing at installing node-red-contrib-bme280.
Can anyone help me out?
Im getting this error:
13 Oct 10:36:52 - [info] Modul wird installiert: node-red-contrib-bme280, Version: 1.0.0
13 Oct 10:37:00 - [warn] Installation des Moduls node-red-contrib-bme280 ist fehlgeschlagen:
13 Oct 10:37:00 - [warn] ------------------------------------------
13 Oct 10:37:00 - [warn] gyp ERR! find VS
gyp ERR! find VS msvs_version not set from command line or npm config
gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
gyp ERR! find VS unknown version "undefined" found at "C:\Program Files\Microsoft Visual Studio\2022\Community"
gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
gyp ERR! find VS looking for Visual Studio 2015
gyp ERR! find VS - not found
gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
gyp ERR! find VS
gyp ERR! find VS **************************************************************
gyp ERR! find VS You need to install the latest version of Visual Studio
gyp ERR! find VS including the "Desktop development with C++" workload.
gyp ERR! find VS For more information consult the documentation at:
gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
gyp ERR! find VS
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Visual Studio installation to use
gyp ERR! stack     at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
gyp ERR! stack     at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
gyp ERR! stack     at ChildProcess.exithandler (child_process.js:397:5)
gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
gyp ERR! stack     at maybeClose (internal/child_process.js:1055:16)
gyp ERR! System Windows_NT 10.0.19043
gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\vital\.node-red\node_modules\i2c-bus
gyp ERR! node -v v14.17.6
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! i2c-bus@5.2.2 install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the i2c-bus@5.2.2 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     C:\Users\vital\AppData\Roaming\npm-cache\_logs\2021-10-13T08_37_00_192Z-debug.log
Error: Installation fehlgeschlagen
    at C:\Users\vital\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\registry\lib\installer.js:245:25
    at processTicksAndRejections (internal/process/task_queues.js:95:5)
13 Oct 10:37:00 - [error] Error: Installation fehlgeschlagen
Thank you very much in advance!
Not being a Windoes user, it seems the answer is right in the output:
I installed Visual Studio 2022 (the latest).
Ill try out with a older Version.
If you look in the node red docs for how to run on Windows it will tell you how to install the build tools.
