Failing installing node-mcp23017
Hello everyone !,
I've been trying to install node-red-contrib-mcp23017 on a freshly installed instance of node red, via the suggested script for raspberry pi (3b+) running the latest raspbian.
Node.js version is v12.14.1
Npm version is Npm 6.13.4
and I keep getting build errors i can't understand, in the installation progress of it's pre-requisite node-mcp23017
this is the output i get: (I'm trimming it because of the character limit)
pi@raspberrypi:~ $ cd .node-red/
pi@raspberrypi:~/.node-red $ npm install node-mcp23017
npm WARN deprecated coffee-script@1.9.1: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
> i2c@0.2.3 install /home/pi/.node-red/node_modules/i2c
> node-gyp rebuild
/home/pi/.cache/node-gyp/12.14.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
../node_modules/nan/nan_object_wrap.h:66:61:   required from here
/home/pi/.cache/node-gyp/12.14.1/include/node/v8.h:10004:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
make: *** [i2c.target.mk:107: Release/obj.target/i2c/src/i2c.o] Error 1
make: Leaving directory '/home/pi/.node-red/node_modules/i2c/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack     at ChildProcess.emit (events.js:223:5)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
gyp ERR! System Linux 4.19.75-v7+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /home/pi/.node-red/node_modules/i2c
gyp ERR! node -v v12.14.1
gyp ERR! node-gyp -v v5.0.5
gyp ERR! not ok
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! i2c@0.2.3 install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the i2c@0.2.3 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /home/pi/.npm/_logs/2020-01-09T23_10_48_409Z-debug.log
I googled around, the "npm ERR!" lines, and here and there people had issues with either node or npm versions, so I tried installing various combination of them, with the only result of getting really frustrated and making random attempts with versions I don't even remember.
I've also been reading this post having appearently the exact same issue, but everything suggestion there, didn't help me anyway.
Before I get lost again in yet another semi-blind attempt to guess the right combination, could any of you help me make sense of these errors or better, if you had any success, pointing me to the right packages to install in order to make it work ?
Thank you all, and if you require more informations, please don't hesitate to ask.
There is one more thing I'm confused about.
I know I need to install node red modules, inside .node-red folder, but I have no idea, and there is no indication in the documentation, on where to install node-mcp23017 that is a nodejs module instead. Should I install it elsewhere or in the same node-red folder ?
also, isn't reverting to an older node/npm version going to mess with compatibility for nodes i'll install later ?
sorry, I'm so very confused
The mcp23017 node installs the i2c node, but the incorrect version. See this topic.
Try installing i2c first:
cd /home/pi/.node-red
npm install https://github.com/nielsnl68/node-red-contrib-i2c.git
Hold on from here:
You want to install node-red-contrib-mcp23017
But you typed: npm install node-mcp23017
2 different things.
1 is a node-red-node,
1 is the nodejs package - which is the one you tried to install.
However, node-red-contrib-mcp23017 has not been updated for 4 years. Perhaps you need to try a more recent version as there are more nodes that support the mcp23017.
May I suggest you use the editor first, it is easier: hamburger menu -> manage palette -> install tab -> search for mcp23017 -> install.
Hi bakman2, thank for steppin in :slight_smile:
I want to install node-red-contrib-mcp23017 (or any other node red module giving me control over mcp23017) but it's prerequisite is node-mcp23017 (which is a nodejs module)
I'll try installing i2c first, thanks !
I could install the i2c library you linked, but when I try to install node-mcp23017 first, it fails with this error
gyp
ERR! build error gyp ERR!
 stack Error: `make` failed with exit code: 2gyp ERR! stack
gyp ERR!
gyp
 ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)gyp ERR!
 System Linux 4.19.75-v7+gyp ERR!
gyp ERR! cwd
gyp
gyp ERR!
node-gyp -v v5.0.5
gyp ERR! not ok [            ......] \ install: info lifecycle i2c@0.2.3~install: Failed to exec install script
npm
npm ERR!
code ELIFECYCLE
npm
ERR! errno 1npm ERR!
npm
ERR! Exit status 1
npm ERR! npm ERR!
npm ERR!
npm
npm ERR!
     /home/pi/.npm/_logs/2020-01-10T09_13_37_353Z-debug.log
I also tried installing mcp23017 nodes from the palette manager, but they also fail, it still seams because of i2c.
I can't pinpoint what the error is telling me, so I have no idea on what to check
Try this one instead
yup it also failed, but I didn't save the log, now i'm in the process of a clean reinstall of node-red, since I have no idea about the leftovers of these attempts, will get back to you as soon as I try again, or have a log of the failure :slight_smile:
...aaand there it is
2020-01-10T09:52:55.155Z [err] make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Error 1
2020-01-10T09:52:55.156Z [out] make: Leaving directory '/home/pi/.node-red/node_modules/i2c-bus/build'
2020-01-10T09:52:55.157Z [err] gyp
2020-01-10T09:52:55.158Z [err]  ERR!
2020-01-10T09:52:55.158Z [err] build error
2020-01-10T09:52:55.160Z [err] gyp
2020-01-10T09:52:55.161Z [err]  ERR! stack Error: `make` failed with exit code: 2
2020-01-10T09:52:55.161Z [err] gyp
2020-01-10T09:52:55.161Z [err] ERR! stack     at ChildProcess.onExit (/opt/nodejs/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
2020-01-10T09:52:55.161Z [err] gyp ERR!
2020-01-10T09:52:55.161Z [err] stack     at ChildProcess.emit (events.js:321:20)
2020-01-10T09:52:55.161Z [err]  stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2020-01-10T09:52:55.162Z [err] gyp
2020-01-10T09:52:55.162Z [err]  ERR! System Linux 4.19.75-v7+
2020-01-10T09:52:55.163Z [err] gyp ERR!
2020-01-10T09:52:55.163Z [err]  command "/opt/nodejs/bin/node" "/opt/nodejs/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2020-01-10T09:52:55.163Z [err]  ERR! cwd /home/pi/.node-red/node_modules/i2c-bus
2020-01-10T09:52:55.163Z [err]  node -v v13.6.0
2020-01-10T09:52:55.164Z [err]  ERR! node-gyp -v v5.0.5
2020-01-10T09:52:55.164Z [err] gyp ERR! not ok
2020-01-10T09:52:55.376Z [err] npm
2020-01-10T09:52:55.376Z [err]  ERR! code ELIFECYCLE
2020-01-10T09:52:55.377Z [err] npm ERR!
2020-01-10T09:52:55.377Z [err]  errno 1
2020-01-10T09:52:55.380Z [err] npm
2020-01-10T09:52:55.381Z [err] ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`
2020-01-10T09:52:55.381Z [err] npm ERR! Exit status 1
2020-01-10T09:52:55.381Z [err]  Failed at the i2c-bus@1.2.5 install script.
2020-01-10T09:52:55.382Z [err]  This is probably not a problem with npm. There is likely additional logging output above.
2020-01-10T09:52:55.415Z [err]
2020-01-10T09:52:55.415Z [err] npm ERR! A complete log of this run can be found in:
2020-01-10T09:52:55.416Z [err] ERR!     /home/pi/.npm/_logs/2020-01-10T09_52_55_386Z-debug.log
2020-01-10T09:52:55.433Z rc=1
Same issue, it tries to install i2c-bus 1.2.5 while the current version lives on 5.x
that's interesting, do you think i should try to make 1.2.5 work, or edit something to work with 5.x ?
I'm no nodejs hero, i believe you can change the contents of package.json which describe the requirements, but how to do that I am not sure, perhaps @TotallyInformation could assist.
Yes, I'm trying that, I'm not sure either how to do that, but thanks for pointing me in this direction !
I've had a bit of play including forking the node and changing dependencies but its a large rabbit hole and I ran out of air :frowning:
I think someone is going to have to start again on a new hierarchy of nodes to make i2c stuff work on a Pi again
For using an MCP23017 as an output device, its might be possible to use an exec node to talk to a python prog - I might try doing that
Hi cymplecy,
thanks, I feel better know knowing that :slight_smile:
I thought to give up and using an exec node to talk to the MCP23017, but I also need it for inputs, besides the fact that I would love to have everything neat and tidy and manage my flows without too many "black boxes I'll forget the workings" :slight_smile:
Did you manage in the end to find the correct versions of modules to work together ?
Moreover is it a bad practice to revert to older versions of modules/nodejs/nodered/npm for security/compatibility or other reasons ? Because I think so, but searching around for solutions to this i2c bedlam, a lot of people adviced to use such and such version.
No - I gave up
I'll let you know if something comes out of the rabbit hole
I am using MCP23017 but had t do a lot to get it working.
The best way to get it working is that you have to be in the directory node-red is installed on,
My directory is /hom/pi/.node-red
npm install i2c-bus@5.1.0
├─┬ i2c-bus@5.1.0
│ ├── bindings@1.5.0 deduped
│ └── nan@2.14.0 deduped (git+https://github.com/nodejs/nan.git#60e86a9d4c4536fbbd2a76814470edd66b23114e)
├── nan@2.14.0 (git+https://github.com/nodejs/nan.git#60e86a9d4c4536fbbd2a76814470edd66b23114e)
You can see I also loaded the latest version of nan@2.14.0 to fix some warnings.
Also install ncd-red-comm@1.6.9 because they all link to it.
This installs all the NCD nodes
npm i $(npm search --parseable ncd-red | cut -f 1)
Once all the packages are installed remember to run npm dedupe and npm rebuild
Once that's done you reboot the system so node-red pulls in the local node_modules files and it should show up in the admin console.
I can help if you get stuck.
Oh wow, thanks vlturner, I'll give this a try as soon as I have some time.
meanwhile, I tried forking the node-mcp23017 and changed it's prerequisite i2c-bus version to the one I was able to install (~5.1.0) and the installation was successful.
Too bad I haven't tried yet with proper hardware connected, will keep you all posted !
Thanks for finding this :slight_smile:
I decided to see if I could get my MCP23017 working as simple as possible without having to install all the other stuff
so i tried
npm install i2c-bus
and
npm install ncd-red-mcp23017
and luckily it worked (after messing around a lot with the settings) and I could switch a LED on/off connected to GPIOA0 (or channel_1 as ncd-red-mcp23017 calls it)
[{"id":"176f6d3d.fddbe3","type":"ncd-mcp23017","z":"70adda38.244c24","name":"","connection":"793838ae.fb2198","addr":"32","interval":"1000","onchange":true,"send_init":true,"outputs":1,"output_all":false,"io_1":1,"io_2":1,"io_3":1,"io_4":1,"io_5":1,"io_6":1,"io_7":1,"io_8":1,"io_9":1,"io_10":1,"io_11":1,"io_12":1,"io_13":1,"io_14":1,"io_15":1,"io_16":1,"persist":"","startup":"","x":850,"y":520,"wires":[["5d1c64a9.34e54c"]]},{"id":"d79aa5fb.a203c8","type":"inject","z":"70adda38.244c24","name":"","topic":"channel_1","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":570,"y":500,"wires":[["176f6d3d.fddbe3"]]},{"id":"e17b0c38.325b5","type":"inject","z":"70adda38.244c24","name":"","topic":"channel_1","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":570,"y":560,"wires":[["176f6d3d.fddbe3"]]},{"id":"5d1c64a9.34e54c","type":"debug","z":"70adda38.244c24","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1180,"y":540,"wires":[]},{"id":"793838ae.fb2198","type":"ncd-comm","z":"","name":"","bus":"i2c-1","commType":"standard","addr":"0","useMux":false,"muxAddr":"112","muxPort":"0"}]
Just noticed this node appear
Works for me (this is on the same Pi as above)
