Yes i reported an issue. I used the link that you posted.
Meanwhile i tested something:
On the second SD-Card i uninstalled the logic node - no problems.
Then i run "apt-get update" and "apt-get dist-upgrade"(apt-get upgrade brings some package dependencies errors) .
When it is done node.js is still v10.15.2 and i can run the intallation of node-red-contrib-nube-logic again without problems. Than i again uninstall it without problems.
Tomorrow i´m trying update node.js by this tutorial:
Don't forget that any time you update the major revision of nodejs (10.x to 12.x for example) then you must re-install node-red and run npm rebuild in the .node-red folder.
I think that tutorial only updates npm, note nodejs.
However, if you now have a working system why not just stick with it?
I updated Node Red with that
script you suggest which also automatically executes an "npm rebuild". After that node.js is V12.14.1 and "surprise" the logic node could no longer be installed.
Next I tried the link I mentioned above, no change ...
To your question why I want to change a working system.
Some other nodes require node.js v12.x ...
But i think i have found a way today how I can implement the program differently, without "node-red-contrib-nube-logic".
I find it annoying when something like this doesn't work, but you've lost a lot of time helping me ...
I think we have to put up with the fact that the "logic node"
cant be installed under node.js 12.14.1at the moment.
Let's see if the issue report against the node brings something...
Thank You all for your time and help!
Greetings Micha
I am confused because I can't get it to build on nodejs 10. The problem appears to the the time module which is called in by the node. npm install time
fails. There is an issue against that module and a PR has been submitted but never actioned. It looks as if the time module is unsupported.
