False or true for an LED Display
Good morning everyone,
I get the following back from a node
{{msg.payload[“000106xxx803”].state.remoteEnable.fullRemoteControl}}
if I enter this therm in a text field, a false or true is also returned
I would also like to display an LED display on the page with the result.
For this I have created a function with the
code:
var new = { payload: msg.payload[“000106xxx803”].state.remoteEnable.fullRemoteControl };
return [new];
Unfortunately, this does not return false or true.
How do I have to do this correctly to get the result I want?
Thanks in advance
Greetings
Roland
Can you connect a debug to the node and set the debug node to show complete message object. Then show the expanded debug so we can verify the content of the property.
Please also verify the dashboard you are using and what led node.
Also, assuming that this is in a function node, you need to return a message, not a simple value, so possibly you need something like
msg.payload = msg.payload[“000106xxx803”].state.remoteEnable.fullRemoteControl
return msg
Also note that, when needed, it is better to use const or let rather than var. Also semi colons are generally not required.
I don't think you can use 'new' as a variable name, as it is a reserved JS token. It will throw a runtime error.
Hello
and thanks for the feedback
Then I will try to clear up the ambiguities
I am using the flow from:
here, the message of the debug node.
This is where the Boolean values arrive.
The path for this is
If I enter this in a TextField, a boolen value is also returned!
even if I enter the term in the debug node like this
a boolean value is returned
payload["000106xxx803"].state.remoteEnable.fullRemoteControl
What / How do I have to do so that I can control an LED with it?
If I insert the function like this
the message comes back
msg.payload["000106xxx803"].state.remoteEnable.fullRemoteControl : undefined
I hope you understand me better now
Roland
As it should, as you have rewritten msg.payload to boolean true, therefore msg.payload["000106xxx803"].state.remoteEnable.fullRemoteControldoes not exist any more. set the debug after the function to complete messgae object
For the sake of completeness
I have solved it like this and I think it works
var msgNeu1 = { payload: msg.payload["000106xxx803"].state.remoteEnable.fullRemoteControl };
return msgNeu1;
Thank you all!
Roland
