How to convert a msg. string object to boolean
First of i am new to node red, but have some experience from arduino.
I am trying to controll my Phillips Hue lights with a Hue switch, that outputs the following when pressed (in this case the "on" button have been pushed):
button: 1002
action: "short released"
updated: "2020-01-08T12:28:17+00:00"
When i listen to msg.payload.name i get "on" and "off" respectively. How do i turn these two string values into a boolean true and false as output?
I know i should be able to do this with the function block, but i am suspecting that there should be an easier way to do this?
In a function you can do
msg.payload = (msg.payload.name === "on")  ?  true  :  false
return msg
or you can configure a Change node like this
which does basically the same thing but using a JSONata expression to test the value.
[Edit] Actually the statement in the function can just be
msg.payload = msg.payload.name === "on"
I could not get your suggestions to work, maybe i did something wrong?
However this function does what i need:
if(msg.payload.name === "On"){
msg.payload = true;
if(msg.payload.name === "Off"){
msg.payload = false;
But if anyone has a more elegant way i would like to try that :slight_smile:
In his examples he had "on" rather than the "On" you show in yours... did you try his with "On" instead ?
ahh nice spottet.... now it works... sort of. Problem here being that there are 4 buttons (On, Off, Dim, Bright). This means that Dim and Bright are also reported as Off, using the first suggestions.
Have a look at the javascript switch statement
https://www.w3schools.com/js/js_switch.asp
In my defence you did say 'When i listen to msg.payload.name i get "on" and "off" respectively'. I had not noticed that this was inconsistent with data a few lines earlier.
Try to use (msg.payload.name. toLowerCase()===“on”) or
switch (msg.payload.name.toLowerCase()) {
 case “on”:
  break;
 case “off”:
  break;
to avoid this kind of problems
Ahh yes that is a nice way to avoid that.
Thank you for all the replies :smiley:
Hi Colin.
Thank you for your reply. I was in no way suggesting that you had anyway of knowing that there were 4 cases. You did answer correctly with the info given by me... i just recaped why i ended up not using your suggestion, because i forgot to mention the full case :slight_smile:
Just wanted to jump in and say thanks to everyone!
I've been using Node-RED with my raspberry pi for awhile using MQTT to control LED lights and a solar powered container watering system. Got stuck when trying Peter Scargills Big Timer which outputs a string to my node-RED Dashboard switch which needed a boolean.
I chose the Change node and need to take some time to learn to use the function node
