Hi all,
This is my first question on this forum. Please keep in mind that i am not a programmer...
I am using node-RED next to my openHAB home automation system instead of the rule engine of openHAB. For scheduler stuff i the use BigTimer node from Peter Scargill which is marvelous!
But i run into a problem with the output of the BigTimer node.
When i switch my Philips Hue light simply with two input nodes, it switches on/off with the input nodes set to true/false respectively.
But the output of the BigTime gives me "true" and "false" in stead of true and false in the debug node. The Hue Light does not accept this, so i think i need to convert "true" to true. Probably i need a function node for this. But i do not know how to configure this properly.
Could somebody please help me with this?
Kind regards, Bert
[{"id":"f2f60fe6.23aad","type":"inject","z":"a84bf6a1.ed57b8","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":280,"wires":[["f21f3a3c.e804a8","f258f7e5.712be8"]]},{"id":"f21f3a3c.e804a8","type":"hue-light","z":"a84bf6a1.ed57b8","name":"Hue color lamp 1","bridge":"f526bb6c.340c08","lightid":"1","colornamer":true,"x":330,"y":200,"wires":[[]]},{"id":"f258f7e5.712be8","type":"debug","z":"a84bf6a1.ed57b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":310,"y":280,"wires":[]},{"id":"84e4b109.c214e","type":"function","z":"a84bf6a1.ed57b8","name":"Return status","func":"return { payload: msg.payload.on };","outputs":1,"noerr":0,"x":670,"y":80,"wires":[["d4f918eb.ef26a8"]]},{"id":"97f4b1c2.f9a3f","type":"inject","z":"a84bf6a1.ed57b8","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":320,"wires":[["f21f3a3c.e804a8","1e7c6d97.2f59a2"]]},{"id":"36eff64c.c90e5a","type":"inject","z":"a84bf6a1.ed57b8","name":"","topic":"","payload":"AUTO","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":360,"wires":[["f21f3a3c.e804a8"]]},{"id":"d4f918eb.ef26a8","type":"ui_switch","z":"a84bf6a1.ed57b8","name":"","label":"Staande schemerlamp","tooltip":"","group":"e631aff1.17e18","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":160,"y":80,"wires":[[]]},{"id":"39c96ca7.504144","type":"inject","z":"a84bf6a1.ed57b8","name":"","topic":"","payload":"AUTO","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":520,"wires":[["bcb985c5.7b2878"]]},{"id":"bcb985c5.7b2878","type":"bigtimer","z":"a84bf6a1.ed57b8","outtopic":"mytimer1","outpayload1":"true","outpayload2":"false","name":"1 - Elke dag Sunset+45 --- 23:30+","comment":"","lat":"51.955","lon":"5.22778","starttime":"5004","endtime":"1410","startoff":"45","endoff":"0","startoff2":"","endoff2":"","offs":0,"outtext1":"Staande Lamp Aan","outtext2":"Staande Lamp Uit","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":"","month6":"","d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":"","w6":"","xday1":"","xmonth1":"","xday2":"","xmonth2":"","xday3":"","xmonth3":"","xday4":"","xmonth4":"","xday5":"","xmonth5":"","xday6":"","xmonth6":"","xd1":"","xw1":"","xd2":"","xw2":"","xd3":"","xw3":"","xd4":"","xw4":"","xd5":"","xw5":"","xd6":"","xw6":"","suspend":false,"random":true,"repeat":false,"atstart":true,"odd":false,"even":false,"x":400,"y":480,"wires":[["2e47657e.d403da","bac75528.08b5d8"],[],[]]},{"id":"96279227.184c1","type":"inject","z":"a84bf6a1.ed57b8","name":"","topic":"","payload":"ON","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":440,"wires":[["bcb985c5.7b2878"]]},{"id":"7619a5c.f7d005c","type":"inject","z":"a84bf6a1.ed57b8","name":"","topic":"","payload":"OFF","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":480,"wires":[["bcb985c5.7b2878"]]},{"id":"2e47657e.d403da","type":"function","z":"a84bf6a1.ed57b8","name":"","func":"if (msg.payload === \"true\" ) { msg.payload = true; }\nelse { msg.payload = '/n'; }\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":660,"wires":[["a95d067c.119b88"]]},{"id":"bac75528.08b5d8","type":"debug","z":"a84bf6a1.ed57b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":730,"y":480,"wires":[]},{"id":"a95d067c.119b88","type":"debug","z":"a84bf6a1.ed57b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":791.0115356445312,"y":660.138916015625,"wires":[]},{"id":"1e7c6d97.2f59a2","type":"debug","z":"a84bf6a1.ed57b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":310,"y":320,"wires":[]},{"id":"f526bb6c.340c08","type":"hue-bridge","z":"","name":"Philips hue","bridge":"192.168.178.233","key":"HEroXcdUipJWSKR46BGNnXfnUsM0KhSPavce5Y-Y","interval":"3000"},{"id":"e631aff1.17e18","type":"ui_group","z":"","name":"4 Woning Bg","tab":"d63e865e.716478","disp":true,"width":"6","collapse":false},{"id":"d63e865e.716478","type":"ui_tab","z":"","name":"4 Woning Bg","icon":"dashboard","order":4,"disabled":false,"hidden":false}]
EDIT.
I found a solution for my issue, using a Function node with a conversion from String to Boolean:
if(msg.payload === "true"){
msg.payload = true;
if(msg.payload === "false"){
msg.payload = false;
Perhaps there are other ways of solving this, but for now i'l stick to this.
Grtz, Bert
