I wanted to try using Node-red and BLE with an ESP32 board and went for the node-red-contrib-generic-ble module.
Unfortunately what's happening now after installing it and briefly getting a successful scan my admin ui freezes and looses connection. When running my UI with the logs in the background the following error is output:
22 Apr 22:47:48 - [info] Starting flows
22 Apr 22:47:48 - [info] Started flows
22 Apr 22:47:48 - [info] [udp in:6ce4b9ad9fbde9d3] udp listener at 0.0.0.0:3435
22 Apr 22:47:48 - [info] [GenericBLE] Start BLE scanning
22 Apr 22:48:09 - [info] Stopping flows
22 Apr 22:48:09 - [info] [udp in:6ce4b9ad9fbde9d3] udp listener stopped
22 Apr 22:48:09 - [info] Stopped flows
22 Apr 22:48:09 - [info] [GenericBLE] Stop BLE scanning
22 Apr 22:48:09 - [info] [GenericBLE] Start BLE scanning
22 Apr 22:48:09 - [info] Updated flows
22 Apr 22:48:09 - [red] Uncaught Exception:
22 Apr 22:48:09 - [error] TypeError: this._discoveredPeripheralUUids.indexOf is not a function
at PeripheralRemovableNoble.onMiss (/home/admin/.node-red/node_modules/node-red-contrib-generic-ble/dist/noble/noble/index.js:61:72)
at BluezBindings.emit (node:events:514:28)
at BluezBindings.onDeviceMissed (/home/admin/.node-red/node_modules/node-red-contrib-generic-ble/dist/noble/lib/bluez/noble/lib/bluez/bindings.js:716:10)
at BluezBindings.onDevicesServicesCharacteristicsMissed (/home/admin/.node-red/node_modules/node-red-contrib-generic-ble/dist/noble/lib/bluez/noble/lib/bluez/bindings.js:710:12)
at ProxyInterface.emit (node:events:514:28)
at EventEmitter.$listeners.<computed> (/home/admin/.node-red/node_modules/dbus-next/lib/client/proxy-interface.js:108:17)
at EventEmitter.emit (node:events:514:28)
at handleMessage (/home/admin/.node-red/node_modules/dbus-next/lib/bus.js:118:23)
at EventEmitter.<anonymous> (/home/admin/.node-red/node_modules/dbus-next/lib/bus.js:147:9)
Couldn't find a similar issue out there so I'm unclear what's unique about my set up and flows. My node-red-server is running on a Pi 4.
Any help is greatly appreciated!
