Hey, right now im having trouble in connecting (The idea is to fetch data) from thingpark actility into node-red. is there any guideline or tutorial that focus more on this?
hi, not something I've come across before. So some more info - like does it have an API ? website ? Is it a hosted solution or something you run yourself... ?
No doubt there will be a way - but...
im create a device in actility and add its application server into the public url destination(using ngrok). i set the content type json. is there any way i can get the the json data or payload by fetching into the url using node-red?
You need to check the actility documentation for what APIs it provides. It isn't a service I've heard of or seen discussed here before, so I'm not sure how much help you'll get.
